Salta al contenuto principale
Logitech M215 Lens Replacement
Cosa ti serve
  1. Logitech M215 Lens Replacement, Remove the battery cover: passo 1, immagine 1 di 3 Logitech M215 Lens Replacement, Remove the battery cover: passo 1, immagine 2 di 3 Logitech M215 Lens Replacement, Remove the battery cover: passo 1, immagine 3 di 3
    • The battery compartment cover is located on the top of the mouse. The seam running horizontally across the mouse is the top of the cover.
    • There is a button to pop off the cover. It is located on the bottom of the mouse. you may need to press hard on this button to pop the cover.
    • If the button does not work, you will need to pry off the cover. You can use your fingernails or a prying tool in order to do this, as seen in the third image.
    Chiedi a FixBot
    Aggiungi Commento
  2. Logitech M215 Lens Replacement, Remove old battery: passo 2, immagine 1 di 1
    • Remember to insert the new battery in the same orientation as the old one. The positive (plus) end should be facing away from the buttons.
    Chiedi a FixBot
    Aggiungi Commento
  3. Logitech M215 Lens Replacement, Top Cover: passo 3, immagine 1 di 2 Logitech M215 Lens Replacement, Top Cover: passo 3, immagine 2 di 2
    • The pads on the underside of the mouse hide the screws. Remove these first. You may need to use your fingernails or a prying tool.
    • There will be two 0.5mm phillips head screws. Both will be underneath the bottom two pads.
    Chiedi a FixBot
    Aggiungi Commento
  4. Logitech M215 Lens Replacement: passo 4, immagine 1 di 1
    • Pry the top cover off. You may need to use a pry tool to help.
    Chiedi a FixBot
    Aggiungi Commento
  5. Logitech M215 Lens Replacement, Motherboard: passo 5, immagine 1 di 2 Logitech M215 Lens Replacement, Motherboard: passo 5, immagine 2 di 2
    • Unscrew the 0.25mm phillips head screw to release the circuit board.
    Chiedi a FixBot
    Aggiungi Commento
  6. Logitech M215 Lens Replacement, Lens: passo 6, immagine 1 di 2 Logitech M215 Lens Replacement, Lens: passo 6, immagine 2 di 2
    • The laser amplifier is not connected to the rest of the mouse and can simply be removed at this point.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Hannah Pate
Membro da: 01/30/15
1.742 Reputazione
7 guide realizzate
USF Tampa, Team 1-1, Watkins Winter 2015 Membro di USF Tampa, Team 1-1, Watkins Winter 2015
USFT-WATKINS-W15S1G1
4 Membri
28 guide realizzate
1Commento della guida
Where i can buy mouse lenses for mk225
Cybermetz X - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 8
Ultimi 30 giorni: 53
Tutti i Tempi: 2,721
