Salta al contenuto principale
Logitech K540 Battery Replacement
Cosa ti serve
  1. Logitech K540 Battery Replacement, Prepare your keyboard for disassembly: passo 1, immagine 1 di 2 Logitech K540 Battery Replacement, Prepare your keyboard for disassembly: passo 1, immagine 2 di 2
    • Slide the power switch on the top right corner to the OFF position.
    • Flip your keyboard over and lay it down so the edge with the two tilt legs is closest to you.
    • If your work surface might scratch the keyboard, place a soft towel under it.
  2. Logitech K540 Battery Replacement, Remove the battery cover: passo 2, immagine 1 di 3 Logitech K540 Battery Replacement, Remove the battery cover: passo 2, immagine 2 di 3 Logitech K540 Battery Replacement, Remove the battery cover: passo 2, immagine 3 di 3
    • Use your finger to pull the tab near the middle of the battery cover inward, towards the center of the cover.
    • With the tab pulled in, lift and remove the cover.
  3. Logitech K540 Battery Replacement, Remove the batteries: passo 3, immagine 1 di 3 Logitech K540 Battery Replacement, Remove the batteries: passo 3, immagine 2 di 3 Logitech K540 Battery Replacement, Remove the batteries: passo 3, immagine 3 di 3
    • Use your finger to lift the edge of the outer battery and remove it.
    • Slide the second battery out of the recess and remove it.
    • During reassembly, slide the batteries in negative (-) end first, as shown in the recess.
Conclusione
Reuse or Recycle—Never put discarded electronic parts in household waste. Visit Logitech Recycling to find your nearest recycling points, including the option to mail back old devices to Logitech for free if there’s no convenient solution in your area. You can also take your e-waste to any R2 or e-Stewards certified recycler. And don’t let good working parts or repaired devices die a slow death in your sock drawer—pass them along to someone who can use them.
Share your experience—Leave a comment here or send your feedback directly to Logitech at repair@logitech.com to help shape future repair guides and product design.
Spencer Day
Membro da: 09/14/22
149.102 Reputazione
995 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 44
Tutti i Tempi: 72
