Salta al contenuto principale
Logitech Harmony Touch Screen Replacement
Cosa ti serve
  1. Logitech Harmony Touch Screen Replacement, Screen: passo 1, immagine 1 di 3 Logitech Harmony Touch Screen Replacement, Screen: passo 1, immagine 2 di 3 Logitech Harmony Touch Screen Replacement, Screen: passo 1, immagine 3 di 3
    • Open the latch that accesses the charging port.
    • Remove the black sticker and remove the screw with the indicated screw driver.
    • Take the plastic opening tool and run it down the side of the remote to pop the case open.
    • While doing this step there are three wires that connect the two pieces, be sure not to rip them out.
    • Detach the white clamp to partially disconnect the case from the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  2. Logitech Harmony Touch Screen Replacement: passo 2, immagine 1 di 2 Logitech Harmony Touch Screen Replacement: passo 2, immagine 2 di 2
    • Peel back thin yellow plastic film and detach the clip found underneath.
    • Use a Phillips #00 to remove the screws that connect the motherboard to the case.
    Chiedi a FixBot
    Aggiungi Commento
  3. Logitech Harmony Touch Screen Replacement: passo 3, immagine 1 di 3 Logitech Harmony Touch Screen Replacement: passo 3, immagine 2 di 3 Logitech Harmony Touch Screen Replacement: passo 3, immagine 3 di 3
    • Carefully remove the motherboard from the top piece of the case.
    • The motherboard is connected to the bottom part of the case.
    • You should be able to access the screen which is located on the back of the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  4. Logitech Harmony Touch Screen Replacement: passo 4, immagine 1 di 1
    • Separate the screen from the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
USF Tampa, Team S4-G2, Eyestone Fall 2017 Membro di USF Tampa, Team S4-G2, Eyestone Fall 2017
USFT-EYESTONE-F17S4G2
4 Membri
5 guide realizzate
2Commenti sulla guida
Hallo
Mit dieser Anleitung klappt das wechseln bestimmt.Ich habe nur eine frage “Woher bekomme ich ein Touchscreen für die Fernbedienung”?
Ich habe die Ultimate und bei mir ist der Touchscreen defekt.Doch ich habe noch kein Ersatz gefunden. :-( Können sie mir da weiter helfen?
belfrea - Rispondi Condividi
do you have the lcd screen P/N???
Alejandro Ortiz - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 13
Ultimi 30 giorni: 86
Tutti i Tempi: 5,557
