Salta al contenuto principale
Logitech Harmony Touch Buttons Replacement
Cosa ti serve
  1. Logitech Harmony Touch Buttons Replacement, Buttons: passo 1, immagine 1 di 3 Logitech Harmony Touch Buttons Replacement, Buttons: passo 1, immagine 2 di 3 Logitech Harmony Touch Buttons Replacement, Buttons: passo 1, immagine 3 di 3
    • Open the latch that accesses the charging port.
    • Remove the black sticker and the screw with the Phillips #0 Screwdriver.
    • Take the plastic opening tool and run it down the side of the remote to open the case.
    • While doing this step, three wires connect the two pieces, be sure not to rip them out.
    • Detach the white clamp to disconnect the case from the motherboard partially.
    Chiedi a FixBot
    Aggiungi Commento
  2. Logitech Harmony Touch Buttons Replacement: passo 2, immagine 1 di 3 Logitech Harmony Touch Buttons Replacement: passo 2, immagine 2 di 3 Logitech Harmony Touch Buttons Replacement: passo 2, immagine 3 di 3
    • Peel back the thin yellow plastic film.
    • Detach the clip found underneath the film.
    • Remove the screws that connect the motherboard to the case with the Phillips #0 Screwdriver.
    Chiedi a FixBot
    Aggiungi Commento
  3. Logitech Harmony Touch Buttons Replacement: passo 3, immagine 1 di 3 Logitech Harmony Touch Buttons Replacement: passo 3, immagine 2 di 3 Logitech Harmony Touch Buttons Replacement: passo 3, immagine 3 di 3
    • Next, carefully remove the motherboard from the top piece of the case.
    • The motherboard is connected to the bottom part of the case.
    • You should now be able to access all the buttons and remove them from the case.
    Chiedi a FixBot
    Aggiungi Commento
  4. Logitech Harmony Touch Buttons Replacement: passo 4, immagine 1 di 2 Logitech Harmony Touch Buttons Replacement: passo 4, immagine 2 di 2
    • Remove the buttons from the case.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
USF Tampa, Team S4-G2, Eyestone Fall 2017 Membro di USF Tampa, Team S4-G2, Eyestone Fall 2017
USFT-EYESTONE-F17S4G2
4 Membri
5 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 4
Ultimi 30 giorni: 17
Tutti i Tempi: 1,902
