Salta al contenuto principale
Logitech Harmony 650 Case Replacement
Cosa ti serve
  1. Logitech Harmony 650 Case Replacement, Case: passo 1, immagine 1 di 2 Logitech Harmony 650 Case Replacement, Case: passo 1, immagine 2 di 2
    • Remove the battery cover by applying pressure to the indented area and pushing the cover toward the rear of the device.
    Chiedi a FixBot
    Aggiungi Commento
  2. Logitech Harmony 650 Case Replacement: passo 2, immagine 1 di 1
    • Remove the batteries using the silver pull tab.
    Chiedi a FixBot
    Aggiungi Commento
  3. Logitech Harmony 650 Case Replacement: passo 3, immagine 1 di 1
    • Using a J000 Philips head screwdriver remove the four 5mm screws around the rim of the battery chamber.
    Chiedi a FixBot
    Aggiungi Commento
  4. Logitech Harmony 650 Case Replacement: passo 4, immagine 1 di 1
    Strumento utilizzato in questo passaggio:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    • Remove the small plastic cover beneath the plastic LED housing by using a 3.0 flathead screwdriver and a spudger to pry it off. It is glued to the case. If you are having trouble removing it try applying some heat to loosen the glue.
    Chiedi a FixBot
    Aggiungi Commento
  5. Logitech Harmony 650 Case Replacement: passo 5, immagine 1 di 1
    • Remove the two 5mm screws located underneath the cover using a J000 Philips screwdriver bit.
    Chiedi a FixBot
    Aggiungi Commento
  6. Logitech Harmony 650 Case Replacement: passo 6, immagine 1 di 2 Logitech Harmony 650 Case Replacement: passo 6, immagine 2 di 2
    • Using a plastic opening tool, pry the case off starting from the top of the device (nearest the transmitter). There are 3 tabs along the side of the case and one at the back.
    • The top led protector plastic cover will also be freed once back is removed.
    Chiedi a FixBot
    Aggiungi Commento
  7. Logitech Harmony 650 Case Replacement: passo 7, immagine 1 di 1
    • Remove the rear cover.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 5 persone hanno completato questa guida.
1Commento della guida
Thanks for the fix. Now I can get on replacing the corroded battery contacts. Many thanks.
Kevin Bonney - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 6
Ultimi 30 giorni: 51
Tutti i Tempi: 3,673
