Salta al contenuto principale
Logitech Gamepad F310 Trigger Spring Replacement
Cosa ti serve
  1. Logitech Gamepad F310 Trigger Spring Replacement, Case: passo 1, immagine 1 di 2 Logitech Gamepad F310 Trigger Spring Replacement, Case: passo 1, immagine 2 di 2
    • Use a Phillips #1 screwdriver to remove all seven 3 mm screws that secure the rear case.
    Chiedi a FixBot
    Aggiungi Commento
  2. Logitech Gamepad F310 Trigger Spring Replacement: passo 2, immagine 1 di 2 Logitech Gamepad F310 Trigger Spring Replacement: passo 2, immagine 2 di 2
    • Press along the seams of the controller and gently pull the front and rear case apart.
    • If necessary, use an opening tool to help pry the front and rear case apart.
    • Make sure to open the controller with the front facing down so that the buttons do not fall out.
    Chiedi a FixBot
    Aggiungi Commento
  3. Logitech Gamepad F310 Trigger Spring Replacement: passo 3, immagine 1 di 1
    • Separate the front and rear case.
    • There are two side panels on the controller that come apart as well. When putting them back together, they slot into place on the sides of the controller.
    Chiedi a FixBot
    Aggiungi Commento
  4. Logitech Gamepad F310 Trigger Spring Replacement, Trigger Spring: passo 4, immagine 1 di 2 Logitech Gamepad F310 Trigger Spring Replacement, Trigger Spring: passo 4, immagine 2 di 2
    • Use a Phillips #1 screwdriver to remove:
    • Four 3 mm screws
    • One 5 mm screw
    • Remove the central silver screw last.
    • Gently lift the motherboard off of the back case and slide the cord out of the top slot.
    Chiedi a FixBot
    Aggiungi Commento
  5. Logitech Gamepad F310 Trigger Spring Replacement: passo 5, immagine 1 di 1
    • Make note of the slot on the controller and the slot on the trigger that the spring is connected to.
    • Press the trigger down until the spring pops loose.
    • You may need to fish the spring out of the pocket it is in. The spring will be accompanied by a small black piece that fits inside the spring.
    Chiedi a FixBot
    Aggiungi Commento
  6. Logitech Gamepad F310 Trigger Spring Replacement: passo 6, immagine 1 di 1
    • In order to properly place the spring into the controller, make sure that the black piece is inside, and make sure each end of the spring goes into the correct slots.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
You're all finished! To reassemble your device, follow these instructions carefully in reverse order.
1Commento della guida
I completed this guide in conjunction with this video:
How to disassemble and reassemble the Logitech Gamepad F310
Khalon - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 4
Ultimi 7 giorni: 24
Ultimi 30 giorni: 114
Tutti i Tempi: 1,602
