Salta al contenuto principale
Logitech Gamepad F310 Buttons Replacement
Cosa ti serve
  1. Logitech Gamepad F310 Buttons Replacement, Case: passo 1, immagine 1 di 2 Logitech Gamepad F310 Buttons Replacement, Case: passo 1, immagine 2 di 2
    • Use a Phillips #1 screwdriver to remove all seven 3 mm screws that secure the rear case.
    Chiedi a FixBot
    Aggiungi Commento
  2. Logitech Gamepad F310 Buttons Replacement: passo 2, immagine 1 di 2 Logitech Gamepad F310 Buttons Replacement: passo 2, immagine 2 di 2
    • Press along the seams of the controller and gently pull the front and rear case apart.
    • If necessary, use an opening tool to help pry the front and rear case apart.
    • Make sure to open the controller with the front facing down so that the buttons do not fall out.
    Chiedi a FixBot
    Aggiungi Commento
  3. Logitech Gamepad F310 Buttons Replacement: passo 3, immagine 1 di 1
    • Separate the front and rear case.
    • There are two side panels on the controller that come apart as well. When putting them back together, they slot into place on the sides of the controller.
    Chiedi a FixBot
    Aggiungi Commento
  4. Logitech Gamepad F310 Buttons Replacement, Buttons: passo 4, immagine 1 di 2 Logitech Gamepad F310 Buttons Replacement, Buttons: passo 4, immagine 2 di 2
    • Remove any buttons that need replacement.
    • The buttons sit loosely in the front of the controller, so flipping the front over will drop all of the buttons out.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
You're all finished! To reassemble your device, follow these instructions in reverse order.
1Commento della guida
Any idea where I can get the d-pad rubber dome replacement part?
Anggoro Arif Junianto - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 5
Ultimi 7 giorni: 21
Ultimi 30 giorni: 74
Tutti i Tempi: 1,395
