Salta al contenuto principale
Logitech G733 Power Button Replacement
Cosa ti serve
    1. Logitech G733 Power Button Replacement, Power Button: passo 1, immagine 1 di 1
      • Before you begin, discharge the headset battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
      • Gently start to pull the left ear pad off, starting from the top.
      • Slide your finger around the edges until it releases completely.
      • Remove the ear pad.
      Chiedi a FixBot
      Aggiungi Commento
    2. Logitech G733 Power Button Replacement: passo 2, immagine 1 di 2 Logitech G733 Power Button Replacement: passo 2, immagine 2 di 2
      • Remove the four screws securing the speaker housing using a T4 Torx screwdriver.
      • Place these screws on the magnetic project mat so you don't lose them.
      Chiedi a FixBot
      Aggiungi Commento
    3. Logitech G733 Power Button Replacement: passo 3, immagine 1 di 3 Logitech G733 Power Button Replacement: passo 3, immagine 2 di 3 Logitech G733 Power Button Replacement: passo 3, immagine 3 di 3
      • Gently lift off the speaker housing, with care not to strain the connected cable.
      • Remove the screw on the bottom right-hand side of the motherboard using a Phillips #000 screwdriver.
      • Use your thumb to gently pull back the tab at the upper right-hand corner of the headphone and simultaneously pull the circuit board out.
      • The scroll wheel may fly out when you pop the circuit board out.
      Chiedi a FixBot
      Aggiungi Commento
    4. Logitech G733 Power Button Replacement: passo 4, immagine 1 di 2 Logitech G733 Power Button Replacement: passo 4, immagine 2 di 2
      • Once the motherboard is loose, gently pull the wire out of its harness.
      • The wiring harness is glued, so be careful with it. It should pull out easily.
      Chiedi a FixBot
      Aggiungi Commento
    5. Logitech G733 Power Button Replacement: passo 5, immagine 1 di 1
      Strumento utilizzato in questo passaggio:
      Halberd Spudger
      $2.99
      • Pop the power button out of its recess by pushing it through the side of the headphone with your finger.
      • Now use the hook end of the halberd spudger to pry the connecting piece of the power button off at the end furthest to the inside of the headphone.
      • This step is the most difficult, so be careful when prying.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 11
Ultimi 30 giorni: 63
Tutti i Tempi: 2,652
