Salta al contenuto principale
Logitech G700s Top Case Replacement
Cosa ti serve
    1. Logitech G700s Top Case Replacement, Top Case Replacement: passo 1, immagine 1 di 1
      • Remove the batteries from the mouse.
      • Use a plastic opening tool to peel up the four mouse feet.
      Chiedi a FixBot
      Aggiungi Commento
    2. Logitech G700s Top Case Replacement: passo 2, immagine 1 di 2 Logitech G700s Top Case Replacement: passo 2, immagine 2 di 2
      • Remove the five 5.5mm Phillips #00 screws found underneath the mouse feet.
      Chiedi a FixBot
      Aggiungi Commento
    3. Logitech G700s Top Case Replacement: passo 3, immagine 1 di 3 Logitech G700s Top Case Replacement: passo 3, immagine 2 di 3 Logitech G700s Top Case Replacement: passo 3, immagine 3 di 3
      • Pull the top of the mouse off of the bottom half.
      • There's a wire connecting the two halves.
      • Unplug the programmable buttons from the motherboard.
      • The white pin housing on the motherboard may come off while unplugging. In that case, use tool to pry between at location indicated to separate them and insert the housing back onto the motherboard.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
USF Tampa, Team S2-G3, Nance Spring 2018 Membro di USF Tampa, Team S2-G3, Nance Spring 2018
USFT-NANCE-S18S2G3
4 Membri
15 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 4
Ultimi 7 giorni: 14
Ultimi 30 giorni: 39
Tutti i Tempi: 3,817
