Salta al contenuto principale
Logitech G603 Wheel Encoder Replacement
Cosa ti serve
    1. Logitech G603 Wheel Encoder Replacement, Remove Top Cover & Batteries: passo 1, immagine 1 di 1
      • Remove magnetic top cover, batteries, and wireless receiver (if currently stored inside the mouse)
      Chiedi a FixBot
      Aggiungi Commento
    2. Logitech G603 Wheel Encoder Replacement, Remove Mouse Feet: passo 2, immagine 1 di 3 Logitech G603 Wheel Encoder Replacement, Remove Mouse Feet: passo 2, immagine 2 di 3 Logitech G603 Wheel Encoder Replacement, Remove Mouse Feet: passo 2, immagine 3 di 3
      • Carefully remove the feet to reveal the 4 screws holding the top and bottom shells together
      • NOTE: These feet can be removed carefully enough to be reused. Only the top and bottom feet need to be removed, not the one around the sensor
      Chiedi a FixBot
      Aggiungi Commento
    3. Logitech G603 Wheel Encoder Replacement, Remove the four Phillips #00 Screws: passo 3, immagine 1 di 1
      • Use Phillips #00 to remove the four bottom screws
      Chiedi a FixBot
      Aggiungi Commento
    4. Logitech G603 Wheel Encoder Replacement, Separate the Top and Bottom Shells: passo 4, immagine 1 di 3 Logitech G603 Wheel Encoder Replacement, Separate the Top and Bottom Shells: passo 4, immagine 2 di 3 Logitech G603 Wheel Encoder Replacement, Separate the Top and Bottom Shells: passo 4, immagine 3 di 3
      • Start at the top above the left and right click and slowly work your way around the shells until they are separated
      • Be careful not to damage the power connector or ribbon cable going from the top shell's boards/battery to the bottom shell's board
      Chiedi a FixBot
      Aggiungi Commento
    5. Logitech G603 Wheel Encoder Replacement, Unplug Power and Ribbon Cables: passo 5, immagine 1 di 3 Logitech G603 Wheel Encoder Replacement, Unplug Power and Ribbon Cables: passo 5, immagine 2 di 3 Logitech G603 Wheel Encoder Replacement, Unplug Power and Ribbon Cables: passo 5, immagine 3 di 3
      • Start with the red and black power cable and gently pull it out
      • Once power cable is removed, you should be able to unfold the two halves and unplug the white ribbon cable
      Chiedi a FixBot
      Aggiungi Commento
    6. Logitech G603 Wheel Encoder Replacement, Remove Encoder Ribbon Cable: passo 6, immagine 1 di 1
      • Gently pull out the black ribbon cable connecting the encoder board to the main board
      Chiedi a FixBot
      Aggiungi Commento
    7. Logitech G603 Wheel Encoder Replacement, Remove 5 Phillips #00 Screws: passo 7, immagine 1 di 1
      • Remove the Phillips #00 screws holding the encoder board in place
      Chiedi a FixBot
      Aggiungi Commento
    8. Logitech G603 Wheel Encoder Replacement, Remove Encoder Board & Wheel: passo 8, immagine 1 di 1
      • Remove the encoder board from the bottom shell
      • Gently remove the wheel from the older encoder board
      • NOTE: The old wheel can be reused in the replacement encoder board
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Jim
Membro da: 06/17/23
331 Reputazione
2 guide realizzate
1Commento della guida
In my case, cleaning the encoder plate in an ultrasonic bath did the trick.
dobromir.dombek - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 4
Ultimi 7 giorni: 36
Ultimi 30 giorni: 203
Tutti i Tempi: 6,369
