Salta al contenuto principale
Logitech G Cloud Left Joystick Replacement
Cosa ti serve
  1. Logitech G Cloud Left Joystick Replacement, Case: passo 1, immagine 1 di 2 Logitech G Cloud Left Joystick Replacement, Case: passo 1, immagine 2 di 2
    • Power the device off and turn it over so the screen is face down.
    • Insert an opening pick into the seam between the back plate and left handguard.
    • Pry around the entire perimeter until the handguard fully releases.
    • Remove the handguard.
    • Repeat the previous three bullets on the right handguard.
  2. Logitech G Cloud Left Joystick Replacement: passo 2, immagine 1 di 1
    • Use a Phillips #00 screwdriver to remove all eight 10 mm screws from the rear case located under where the handguards were.
  3. Logitech G Cloud Left Joystick Replacement: passo 3, immagine 1 di 2 Logitech G Cloud Left Joystick Replacement: passo 3, immagine 2 di 2
    • Insert an opening pick into the seam between the midframe and rear case.
    • Gently pry the rear case upwards to separate it from the midframe.
  4. Logitech G Cloud Left Joystick Replacement: passo 4, immagine 1 di 1
    • Use a Phillips #00 screwdriver to remove all seven 10 mm screws that secure the midframe.
  5. Logitech G Cloud Left Joystick Replacement: passo 5, immagine 1 di 2 Logitech G Cloud Left Joystick Replacement: passo 5, immagine 2 di 2
    • Insert an opening pick into the seam between the midframe and front case at the top of the device to separate the interior plating.
    • Gently pry out the midframe by lifting an opening pick.
    • You may hear loud popping noises when you remove the interior plating. That's the sound of the retaining clips disengaging.
  6. Logitech G Cloud Left Joystick Replacement, Left Joystick: passo 6, immagine 1 di 2 Logitech G Cloud Left Joystick Replacement, Left Joystick: passo 6, immagine 2 di 2
    • Use a Phillips #00 screwdriver to remove the two 10 mm screws that secure the L2 trigger.
    • Pop the L2 trigger out with your fingers.
  7. Logitech G Cloud Left Joystick Replacement: passo 7, immagine 1 di 3 Logitech G Cloud Left Joystick Replacement: passo 7, immagine 2 di 3 Logitech G Cloud Left Joystick Replacement: passo 7, immagine 3 di 3
    • Use a spudger to lift upwards and disconnect the metallic sticker from the console.
    • The sticker should stay attached to the joystick plate.
    • Insert the flat end of a spudger under the joystick press connector and lift upwards to disconnect it.
    • Use a spudger to remove the L2 trigger sensor from the joystick plate; it should stay attached to the console.
  8. Logitech G Cloud Left Joystick Replacement: passo 8, immagine 1 di 2 Logitech G Cloud Left Joystick Replacement: passo 8, immagine 2 di 2
    • Use a Phillips #00 screwdriver to remove all three 10 mm screws that secure the joystick assembly.
    • Pop the joystick out with your fingers.
Conclusione
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 49
Tutti i Tempi: 304
