Salta al contenuto principale
Logitech G Cloud Case Replacement
Cosa ti serve
  1. Logitech G Cloud Case Replacement, Case: passo 1, immagine 1 di 2 Logitech G Cloud Case Replacement, Case: passo 1, immagine 2 di 2
    • Power the device off and turn it over so the screen is face down.
    • Insert an opening pick into the seam between the back plate and left handguard.
    • Pry around the entire perimeter until the handguard fully releases.
    • Remove the handguard.
    • Repeat the previous three bullets on the right handguard.
    Chiedi a FixBot
    Aggiungi Commento
  2. Logitech G Cloud Case Replacement: passo 2, immagine 1 di 1
    • Use a Phillips #00 screwdriver to remove all eight 10 mm screws from the rear case located under where the handguards were.
    Chiedi a FixBot
    Aggiungi Commento
  3. Logitech G Cloud Case Replacement: passo 3, immagine 1 di 2 Logitech G Cloud Case Replacement: passo 3, immagine 2 di 2
    • Insert an opening pick into the seam between the midframe and rear case.
    • Gently pry the rear case upwards to separate it from the midframe.
    Chiedi a FixBot
    Aggiungi Commento
  4. Logitech G Cloud Case Replacement: passo 4, immagine 1 di 1
    • Use a Phillips #00 screwdriver to remove all seven 10 mm screws that secure the midframe.
    Chiedi a FixBot
    Aggiungi Commento
  5. Logitech G Cloud Case Replacement: passo 5, immagine 1 di 2 Logitech G Cloud Case Replacement: passo 5, immagine 2 di 2
    • Insert an opening pick into the seam between the midframe and front case at the top of the device to separate the interior plating.
    • Gently pry out the midframe by lifting an opening pick.
    • You may hear loud popping noises when you remove the interior plating. That's the sound of the retaining clips disengaging.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 8
Ultimi 30 giorni: 55
Tutti i Tempi: 545
