Salta al contenuto principale
Logitech Circle Ribbon Cable Replacement
Cosa ti serve
  1. Logitech Circle Ribbon Cable Replacement, Ribbon Cable: passo 1, immagine 1 di 2 Logitech Circle Ribbon Cable Replacement, Ribbon Cable: passo 1, immagine 2 di 2
    • Wedge the plastic opening tool under the black circle lens and gently pry it off.
    • The lens is only attached with sticky tape and should remove relatively easily.
    Chiedi a FixBot
    Aggiungi Commento
  2. Logitech Circle Ribbon Cable Replacement: passo 2, immagine 1 di 2 Logitech Circle Ribbon Cable Replacement: passo 2, immagine 2 di 2
    • Remove the four 3mm Phillips #0 screws that hold down the first ring.
    Chiedi a FixBot
    Aggiungi Commento
  3. Logitech Circle Ribbon Cable Replacement: passo 3, immagine 1 di 2 Logitech Circle Ribbon Cable Replacement: passo 3, immagine 2 di 2
    • Remove the four 3mm Phillips #0 screws that hold down the second ring.
    Chiedi a FixBot
    Aggiungi Commento
  4. Logitech Circle Ribbon Cable Replacement: passo 4, immagine 1 di 2 Logitech Circle Ribbon Cable Replacement: passo 4, immagine 2 di 2
    • Remove the four 3mm Phillips #0 screws that hold down the final ring. Do not remove the lens/battery bundle yet.
    • The lens/battery bundle is attached to the base by a ribbon cable that can break, so be very careful handling the circle.
    Chiedi a FixBot
    Aggiungi Commento
  5. Logitech Circle Ribbon Cable Replacement: passo 5, immagine 1 di 2 Logitech Circle Ribbon Cable Replacement: passo 5, immagine 2 di 2
    • Gently remove the lens/battery bundle from the base of the circle, being mindful of the ribbon cable.
    Chiedi a FixBot
    Aggiungi Commento
  6. Logitech Circle Ribbon Cable Replacement: passo 6, immagine 1 di 2 Logitech Circle Ribbon Cable Replacement: passo 6, immagine 2 di 2
    • Gently pull the ribbon cable loose from the lens/battery bundle.
    • While this is not an entirely necessary step, it helps to ensure the ribbon cable will not break during the rest of the replacement.
    Chiedi a FixBot
    Aggiungi Commento
  7. Logitech Circle Ribbon Cable Replacement: passo 7, immagine 1 di 3 Logitech Circle Ribbon Cable Replacement: passo 7, immagine 2 di 3 Logitech Circle Ribbon Cable Replacement: passo 7, immagine 3 di 3
    • Once the old ribbon cable has been detached from the lens/battery bundle it's time to release the other side from the base.
    • Locate the screws holding the base together by feeling for the soft spots underneath the manufacturer's sticker. Punch through with your screwdriver and remove the three 3mm Phillips #0 screws.
    • The two pieces of the base can now be easily pulled apart.
    Chiedi a FixBot
    Aggiungi Commento
  8. Logitech Circle Ribbon Cable Replacement: passo 8, immagine 1 di 2 Logitech Circle Ribbon Cable Replacement: passo 8, immagine 2 di 2
    • Gently pull the ribbon cable loose from its connection to the base.
    Chiedi a FixBot
    Aggiungi Commento
  9. Logitech Circle Ribbon Cable Replacement: passo 9, immagine 1 di 2 Logitech Circle Ribbon Cable Replacement: passo 9, immagine 2 di 2
    • Slide the push pin holding the plastic connector/ribbon cable in place out on both sides.
    Chiedi a FixBot
    Aggiungi Commento
  10. Logitech Circle Ribbon Cable Replacement: passo 10, immagine 1 di 1
    • Remove the black plastic connector and the two springs from the base of the device.
    Chiedi a FixBot
    Aggiungi Commento
  11. Logitech Circle Ribbon Cable Replacement: passo 11, immagine 1 di 1
    • Reach inside the circle and pull the ribbon cable free from the device.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Haley Williams
Membro da: 09/28/17
112 Reputazione
Una guida realizzata
6Commenti sulla guida
where can I buy such a cable?
kersop@gmail.com
Nico Kersop - Rispondi Condividi
The cable I received from China is not the right one. Where do you buy the correct one?
Helen - Rispondi Condividi
Can you advise where to buy the correct cable?
Michele Ingratta - Rispondi Condividi
I have cable has beark off. I need that cable.
Where can I find
Alican Döşlü - Rispondi Condividi
i also need that cable
l_samin - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 14
Ultimi 30 giorni: 41
Tutti i Tempi: 2,713
