Salta al contenuto principale
Liquid Damage Technique
Cosa ti serve
    1. Liquid Damage Technique, Top Casing: passo 1, immagine 1 di 1
      • Power down and unplug the device.
      Chiedi a FixBot
      Aggiungi Commento
    2. Liquid Damage Technique: passo 2, immagine 1 di 1
      Chiedi a FixBot
      Aggiungi Commento
    3. Liquid Damage Technique: passo 3, immagine 1 di 1
      • Remove the two black rubber feet of the device using the screwdriver. The feet are located on the bottom towards the front.
      Chiedi a FixBot
      Aggiungi Commento
    4. Liquid Damage Technique: passo 4, immagine 1 di 1
      • Once the feet are removed, two small screws will be visible. With a small screwdriver, unscrew them. Screws are phillips head, 4.35 mm in diameter, 7.88 mm in length.
      Chiedi a FixBot
      Aggiungi Commento
    5. Liquid Damage Technique: passo 5, immagine 1 di 1
      • To remove the front blue panel, grip firmly and place thumbs in the two notches on top. Push thumbs forward while keeping a firm grip on bottom.
      • This may require a bit of force.
      Chiedi a FixBot
      Aggiungi Commento
    6. Liquid Damage Technique: passo 6, immagine 1 di 1
      • Now slide the bottom panel forward and remove it so the top casing is isolated from the bottom casing and motherboard.
      Chiedi a FixBot
      Aggiungi Commento
    7. Liquid Damage Technique: passo 7, immagine 1 di 2 Liquid Damage Technique: passo 7, immagine 2 di 2
      • Unscrew the nut on the outer side of the back casing. Remove the nut and the washer from both antenna mounts.
      Chiedi a FixBot
      Aggiungi Commento
    8. Liquid Damage Technique: passo 8, immagine 1 di 2 Liquid Damage Technique: passo 8, immagine 2 di 2
      • From here, remove the wires and nuts connected to the back panel by pulling the nuts through the holes.
      • Now the top casing has been removed and isolated from the rest of the device. From here, you can make repairs to the top casing.
      • Once the top panel is removed the main board will still be attached to the bottom panel.
      Chiedi a FixBot
      Aggiungi Commento
    1. Liquid Damage Technique, Bottom Casing/Motherboard: passo 9, immagine 1 di 2 Liquid Damage Technique, Bottom Casing/Motherboard: passo 9, immagine 2 di 2
      • Unscrew the two screws that connect the motherboard to the bottom casing.
      • The motherboard and bottom casing should be completely separated at this point. This allows for replacement of the motherboard and/ or its components as well as the bottom casing.
      Chiedi a FixBot
      Aggiungi Commento
    1. Liquid Damage Technique, Liquid Damage Technique: passo 10, immagine 1 di 1
      • If the spilled substance is dry use a cleaning tool such as a toothbrush with soft bristles, so you do not damage the device, to brush off as much of the foreign material as possible.
      Chiedi a FixBot
      Aggiungi Commento
    2. Liquid Damage Technique: passo 11, immagine 1 di 1
      • Dry off circuit board with kitchen paper; using other types of paper products such as toilet paper will fall apart. Be sure not to rub but carefully apply pressure to dry up wet spots.
      Chiedi a FixBot
      Aggiungi Commento
    3. Liquid Damage Technique: passo 12, immagine 1 di 1
      • Clean off the components to make sure the rest of the residue comes off by using a chemical gasoline or another solvent that contains one substance that evaporates quickly.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
After the device is cleaned and put back together it should work properly.
Cal Poly, Team 21-21, Maness Fall 2011 Membro di Cal Poly, Team 21-21, Maness Fall 2011
CPSU-MANESS-F11S21G21
5 Membri
12 guide realizzate
1Commento della guida
I did all of this still not working it gets hot only but doesn’t turn it on.
DM MG - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 11
Ultimi 30 giorni: 42
Tutti i Tempi: 7,792
