Salta al contenuto principale
Linksys WRT54GS v2 Power Connector Replacement
Cosa ti serve
  1. Linksys WRT54GS v2 Power Connector Replacement, Front Case: passo 1, immagine 1 di 1
    • Turn the router over so that all four of its feet are facing upwards.
  2. Linksys WRT54GS v2 Power Connector Replacement: passo 2, immagine 1 di 1
    • Remove the rubber inserts inside the the two purple feet located on the router's front case.
    • This may be a challenge, so try the following two methods:
    • Use a plastic opening tool. Insert the flat end of the tool into the seam and slowly pry the rubber feet out.
    • Use a metal spudger. Insert the point of the metal spudger directly into the hole of the rubber feet and pry the insert out.
  3. Linksys WRT54GS v2 Power Connector Replacement: passo 3, immagine 1 di 1
    • Use a Phillips #2 Screwdriver to remove the two 5.8 mm screws holding the front case to the motherboard.
  4. Linksys WRT54GS v2 Power Connector Replacement: passo 4, immagine 1 di 1
    • Squeeze the sides of the router's backcase inward and pull off the purple front case. It is helpful to have a second person assist you for this step.
  5. Linksys WRT54GS v2 Power Connector Replacement, Motherboard: passo 5, immagine 1 di 1
    • Slide the board unit out and up.
  6. Linksys WRT54GS v2 Power Connector Replacement: passo 6, immagine 1 di 1
    • Flip the circuit board over and use a Phillips #2 Screwdriver to remove the 6.9mm screw holding the board to the back case.
    • Slide the back cover out and away from the circuit board.
  7. Linksys WRT54GS v2 Power Connector Replacement, Power Connector: passo 7, immagine 1 di 1
    • Turn the circuit board over.
    • Identify the solder connections on the board, marked in red.
  8. Linksys WRT54GS v2 Power Connector Replacement: passo 8, immagine 1 di 1
    • Desolder the connection by following iFixit's guide to repairing soldered connections: Come saldare e dissaldare componenti elettrici.
    • Remove the Power Connector from the board.
    • Insert the replacement power port and resolder the connectors.
Conclusione
Alex Do
Membro da: 10/12/11
51 Reputazione
1 Guida realizzata
Cal Poly, Team 3-4, Regan Fall 2011 Membro di Cal Poly, Team 3-4, Regan Fall 2011
CPSU-REGAN-F11S3G4
4 Membri
12 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 20
Tutti i Tempi: 1,899
