Salta al contenuto principale
Linksys WRT54G Motherboard Component Replacement
Cosa ti serve
  1. Linksys WRT54G Motherboard Component Replacement, Antennas: passo 1, immagine 1 di 1
    • Unfold the antennas straight away from the device.
  2. Linksys WRT54G Motherboard Component Replacement: passo 2, immagine 1 di 3 Linksys WRT54G Motherboard Component Replacement: passo 2, immagine 2 di 3 Linksys WRT54G Motherboard Component Replacement: passo 2, immagine 3 di 3
    • Remove the black caps from the antennas by pulling them away from the device.
  3. Linksys WRT54G Motherboard Component Replacement: passo 3, immagine 1 di 3 Linksys WRT54G Motherboard Component Replacement: passo 3, immagine 2 di 3 Linksys WRT54G Motherboard Component Replacement: passo 3, immagine 3 di 3
    • Unscrew each of the antennas from the wireless device.
  4. Linksys WRT54G Motherboard Component Replacement, Casing: passo 4, immagine 1 di 2 Linksys WRT54G Motherboard Component Replacement, Casing: passo 4, immagine 2 di 2
    • Using a bit of force, remove the blue plastic case.
  5. Linksys WRT54G Motherboard Component Replacement, Motherboard: passo 5, immagine 1 di 2 Linksys WRT54G Motherboard Component Replacement, Motherboard: passo 5, immagine 2 di 2
    • To remove the black casing that surrounds the green motherboard, slide the top half of the casing backwards. It only moves a very short distance.
    • Pull the top piece upwards and away from the bottom to remove.
  6. Linksys WRT54G Motherboard Component Replacement: passo 6, immagine 1 di 2 Linksys WRT54G Motherboard Component Replacement: passo 6, immagine 2 di 2
    • Locate the 2 M2.5x6mm screws that attach the motherboard to the back case.
    • Remove the two screws from the motherboard as indicated with the Phillips head screwdriver.
  7. Linksys WRT54G Motherboard Component Replacement: passo 7, immagine 1 di 1
    • Once screws have been removed, slide the motherboard in the direction of its LED lights.
    • Lift motherboard up and away from the black lower casing.
  8. Linksys WRT54G Motherboard Component Replacement, Motherboard Component: passo 8, immagine 1 di 1
    • Obtain a desoldering wick (Desoldering Braid). Plug in soldering iron and allow to heat. For soldering information, refer to the iFixit soldering guide (Come saldare e dissaldare componenti elettrici).
    • Make sure that the soldering iron is not resting on top of anything that would be damaged by the heat.
  9. Linksys WRT54G Motherboard Component Replacement: passo 9, immagine 1 di 2 Linksys WRT54G Motherboard Component Replacement: passo 9, immagine 2 di 2
    • Identify the functional component which will be removed.
    • Turn the board over so that the pins holding the component in are exposed.
  10. Linksys WRT54G Motherboard Component Replacement: passo 10, immagine 1 di 1
Conclusione
Nicole C
Membro da: 10/12/11
102 Reputazione
1 Guida realizzata
Cal Poly, Team 17-7, Regan Fall 2011 Membro di Cal Poly, Team 17-7, Regan Fall 2011
CPSU-REGAN-F11S17G7
4 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 10
Tutti i Tempi: 3,740
