Salta al contenuto principale
Levoit Core 300-RAC Control Board Replacement
Cosa ti serve
    1. Levoit Core 300-RAC Control Board Replacement, Control Board: passo 1, immagine 1 di 3 Levoit Core 300-RAC Control Board Replacement, Control Board: passo 1, immagine 2 di 3 Levoit Core 300-RAC Control Board Replacement, Control Board: passo 1, immagine 3 di 3
      • Make sure the device is turned off and unplugged before disassembling it.
      • Insert the Jimmy between the gray grille cover and the top of the device.
      • Work your way around the grille cover with the Jimmy to release the clips holding it in place.
      • Take note of the placement of the clips, as they are keyed and need to go back in the exact way they came out.
      • Remove the grille cover gently as it is connected by a ribbon cable.
      • Be careful not to put too much strain on the ribbon cable as it may break.
      Chiedi a FixBot
      Aggiungi Commento
    2. Levoit Core 300-RAC Control Board Replacement: passo 2, immagine 1 di 3 Levoit Core 300-RAC Control Board Replacement: passo 2, immagine 2 di 3 Levoit Core 300-RAC Control Board Replacement: passo 2, immagine 3 di 3
      • Squeeze the tab on the connector to release the bundled cable from the control board.
      • The connector should come out fairly easily, so do not force it. Pulling too hard could damage the connector.
      Chiedi a FixBot
      Aggiungi Commento
    3. Levoit Core 300-RAC Control Board Replacement: passo 3, immagine 1 di 2 Levoit Core 300-RAC Control Board Replacement: passo 3, immagine 2 di 2
      • Gently bend the gray plastic cover to release the control board.
      • There are several hard tabs holding the control board in place.
      Chiedi a FixBot
      Aggiungi Commento
    4. Levoit Core 300-RAC Control Board Replacement: passo 4, immagine 1 di 3 Levoit Core 300-RAC Control Board Replacement: passo 4, immagine 2 di 3 Levoit Core 300-RAC Control Board Replacement: passo 4, immagine 3 di 3
      • Lift the control board from the gray plastic cover.
      • Take note of the orientations of the buttons, as that will help during reassembly.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Mustafa
Membro da: 11/03/23
259 Reputazione
Una guida realizzata
UMass Dartmouth, Team 1-6, Petersen Fall 2023 Membro di UMass Dartmouth, Team 1-6, Petersen Fall 2023
UMASSD-PETERSEN-F23S1G6
5 Membri
56 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 26
Ultimi 30 giorni: 96
Tutti i Tempi: 1,926
