Salta al contenuto principale
Lenovo ThinkPad X395 Back Cover Replacement
Cosa ti serve
  1. Lenovo ThinkPad X395 Back Cover Replacement, Loosen the back screws: passo 1, immagine 1 di 2 Lenovo ThinkPad X395 Back Cover Replacement, Loosen the back screws: passo 1, immagine 2 di 2
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use a Phillips #1 screwdriver to fully loosen the five screws on the back cover.
    • These are captive screws—they won't come out after being loosened.
  2. Lenovo ThinkPad X395 Back Cover Replacement, Release the clips: passo 2, immagine 1 di 2 Lenovo ThinkPad X395 Back Cover Replacement, Release the clips: passo 2, immagine 2 di 2
    • Orient your laptop so that the screen's silver hinges are closest to you.
    • Insert an opening pick between the back cover and the device body near a hinge corner.
    • Pry upward to release the retaining clips. Listen for a loud click when each clip releases.
  3. Lenovo ThinkPad X395 Back Cover Replacement: passo 3, immagine 1 di 2 Lenovo ThinkPad X395 Back Cover Replacement: passo 3, immagine 2 di 2
    • Insert the opening pick between the back cover and the device body at the other hinge corner.
    • Pry upward on the cover to release additional clips.
  4. Lenovo ThinkPad X395 Back Cover Replacement, Remove the back cover: passo 4, immagine 1 di 3 Lenovo ThinkPad X395 Back Cover Replacement, Remove the back cover: passo 4, immagine 2 di 3 Lenovo ThinkPad X395 Back Cover Replacement, Remove the back cover: passo 4, immagine 3 di 3
    • Lift and remove the cover up from the laptop, starting with the edge nearest to you.
    • Shift the cover side to side if the center clip feels stuck.
    • The cover will hinge open before completely separating from the rest of the laptop.
Conclusione
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Lenovo ThinkPad answers community for help.
Clay Eickemeyer
Membro da: 09/19/22
81.842 Reputazione
455 Guide realizzate
Guide Team Membro di Guide Team
Staff
9 Membri
11.419 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 31
Ultimi 30 Giorni: 112
Tutti i Tempi: 3,148
