Salta al contenuto principale
Lenovo ThinkPad X390 Battery Replacement
Cosa ti serve
  1. Lenovo ThinkPad X390 Battery Replacement, Back Cover: passo 1, immagine 1 di 1
    • Turn off and power down the laptop before proceeding with the guide.
    • Flip your laptop over and place on a flat surface so you can access the screws on the base cover.
    • Using a Phillips #0 screwdriver, unscrew the five screws on the base cover.
    • The screws are not removable.
  2. Lenovo ThinkPad X390 Battery Replacement: passo 2, immagine 1 di 2 Lenovo ThinkPad X390 Battery Replacement: passo 2, immagine 2 di 2
    • Remove the base cover by inserting a plastic opening tool in between the cover and the rest of the laptop.
    • Once the tool is inserted, slide the tool along the edges of the case and push down on the opening tool to detach the case.
    • You may need to move the tool to different locations to fully release the back cover.
  3. Lenovo ThinkPad X390 Battery Replacement, Battery: passo 3, immagine 1 di 2 Lenovo ThinkPad X390 Battery Replacement, Battery: passo 3, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Using tweezers, unplug the battery from the laptops motherboard by pulling on the cable that attaches it.
  4. Lenovo ThinkPad X390 Battery Replacement: passo 4, immagine 1 di 2 Lenovo ThinkPad X390 Battery Replacement: passo 4, immagine 2 di 2
    • Using a Phillips #0 screwdriver, remove the four 5.2 mm screws holding the battery in place.
  5. Lenovo ThinkPad X390 Battery Replacement: passo 5, immagine 1 di 2 Lenovo ThinkPad X390 Battery Replacement: passo 5, immagine 2 di 2
    • Using your hands, remove the battery from the laptop.
Conclusione
For optimal performance, after completing this guide, calibrate your newly installed battery.
Altre 2 persone hanno completato questa guida.
Clemson, Team 5-1, Hunter Fall 2021 Membro di Clemson, Team 5-1, Hunter Fall 2021
CLEM-HUNTER-F21S5G1
5 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 8
Ultimi 7 Giorni: 56
Ultimi 30 Giorni: 249
Tutti i Tempi: 4,065
