Salta al contenuto principale
Lenovo ThinkPad X1 Yoga 2nd Generation Battery Replacement
Cosa ti serve
  1. Lenovo ThinkPad X1 Yoga 2nd Generation Battery Replacement, Back Cover: passo 1, immagine 1 di 1
    • Ensure the laptop is powered off and the charging cable is disconnected before opening the back cover.
    • Flip over the laptop to access the back cover.
  2. Lenovo ThinkPad X1 Yoga 2nd Generation Battery Replacement: passo 2, immagine 1 di 2 Lenovo ThinkPad X1 Yoga 2nd Generation Battery Replacement: passo 2, immagine 2 di 2
    • Use a Phillips #0 screwdriver to remove the eight 8 mm screws.
    More pricesely, screws need to be unscrewed, but not removed, since they stay attached to the back cover. Trying to remove them may damage the small gaskets around the screw shaft.
    Edouard Rossignol - Replica
  3. Lenovo ThinkPad X1 Yoga 2nd Generation Battery Replacement: passo 3, immagine 1 di 1
    • Remove the back cover.
    • A popping sound may occur when the back cover is removed.
    Good solution, but where do I find the battery?
    Brian Arnold - Replica
  4. Lenovo ThinkPad X1 Yoga 2nd Generation Battery Replacement, Speakers: passo 4, immagine 1 di 2 Lenovo ThinkPad X1 Yoga 2nd Generation Battery Replacement, Speakers: passo 4, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    $3.99
    • Follow the ribbon cable that runs from the left speaker to the motherboard.
    • Pull the black connector up and release the cable wire by hand.
    • If needed, pull this connector up using the Pro/ESD/angled tweezers.
  5. Lenovo ThinkPad X1 Yoga 2nd Generation Battery Replacement: passo 5, immagine 1 di 2 Lenovo ThinkPad X1 Yoga 2nd Generation Battery Replacement: passo 5, immagine 2 di 2
    • Remove two 6 mm Phillips #0 screws from each speaker.
  6. Lenovo ThinkPad X1 Yoga 2nd Generation Battery Replacement: passo 6, immagine 1 di 2 Lenovo ThinkPad X1 Yoga 2nd Generation Battery Replacement: passo 6, immagine 2 di 2
    • Use your fingers to remove the speakers from the device.
  7. Lenovo ThinkPad X1 Yoga 2nd Generation Battery Replacement, Battery: passo 7, immagine 1 di 1
    • Use a spudger to pop the ribbon cable that runs from the upper-middle portion of the battery to the motherboard out of the motherboard.
    • Do not use a metal spudger as indicated in the photos. The metal spudger should only be used for serious prying power. If it's used on the internal components of a device, it may puncture or damage the components in your device.
  8. Lenovo ThinkPad X1 Yoga 2nd Generation Battery Replacement: passo 8, immagine 1 di 1
    • Use a Phillips #0 screwdriver to remove one 6 mm screw from the bottom-middle portion of the battery.
  9. Lenovo ThinkPad X1 Yoga 2nd Generation Battery Replacement: passo 9, immagine 1 di 1
    • Remove the battery.
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team S22-G3, Regan Winter 2020 Membro di Cal Poly, Team S22-G3, Regan Winter 2020
CPSU-REGAN-W20S22G3
5 Membri
7 Guide realizzate
4Commenti sulla guida
thank for your good job ;-)
michaël cadot - Replica
Thank you for an excellent
John Kihl - Replica
Where is a good place to buy a replacement battery?
Johann Lopez - Replica
Any idea where to find the battery? Not listed for sale on ifixit
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 22
Ultimi 30 Giorni: 127
Tutti i Tempi: 9,298
