Salta al contenuto principale
Lenovo ThinkPad T480s Wi-Fi Card Replacement
Cosa ti serve
  1. Lenovo ThinkPad T480s Wi-Fi Card Replacement, Bottom Cover: passo 1, immagine 1 di 2 Lenovo ThinkPad T480s Wi-Fi Card Replacement, Bottom Cover: passo 1, immagine 2 di 2
    • Disable the battery, power down the device, and unplug the power adapter from your device before proceeding/beginning the guide.
    • Loosen the six captive screws with a Phillips #1 screwdriver.
  2. Lenovo ThinkPad T480s Wi-Fi Card Replacement: passo 2, immagine 1 di 3 Lenovo ThinkPad T480s Wi-Fi Card Replacement: passo 2, immagine 2 di 3 Lenovo ThinkPad T480s Wi-Fi Card Replacement: passo 2, immagine 3 di 3
    • Remove the bottom cover with an opening tool.
    • Start from the top edge near the hinge and work your way along the edge until all of the clips are unsnapped.
  3. Lenovo ThinkPad T480s Wi-Fi Card Replacement: passo 3, immagine 1 di 2 Lenovo ThinkPad T480s Wi-Fi Card Replacement: passo 3, immagine 2 di 2
    • Lift the bottom cover off.
  4. Lenovo ThinkPad T480s Wi-Fi Card Replacement, Wi-Fi Card: passo 4, immagine 1 di 3 Lenovo ThinkPad T480s Wi-Fi Card Replacement, Wi-Fi Card: passo 4, immagine 2 di 3 Lenovo ThinkPad T480s Wi-Fi Card Replacement, Wi-Fi Card: passo 4, immagine 3 di 3
    • Using the nylon spudger, pop the coaxial antenna wires off the Wi-Fi card.
    • When reassembling, reattach the gray wire closest to the screw and the black wire on the other side of the gray wire.
  5. Lenovo ThinkPad T480s Wi-Fi Card Replacement: passo 5, immagine 1 di 2 Lenovo ThinkPad T480s Wi-Fi Card Replacement: passo 5, immagine 2 di 2
    • Use the Phillips #1 screwdriver to remove one 2.8mm screw holding the Wi-Fi card down to the motherboard.
  6. Lenovo ThinkPad T480s Wi-Fi Card Replacement: passo 6, immagine 1 di 3 Lenovo ThinkPad T480s Wi-Fi Card Replacement: passo 6, immagine 2 di 3 Lenovo ThinkPad T480s Wi-Fi Card Replacement: passo 6, immagine 3 di 3
    • Slide the Wi-Fi card out from the slot.
Conclusione
Altre 2 persone hanno completato questa guida.
Sarah Westberg
Membro da: 03/11/19
34.887 Reputazione
71 Guide realizzate
iFixit Membro di iFixit
Staff
123 Membri
23.618 Guide realizzate
1Commento della guida
Hi, thanks a lot the helpful guide. I have just replaced the WiFi card in my Lenovo T480s with a Intel AX210NGW. My laptop won't boot up. Even when I plug the power adapter into the laptop, the status indicator does not light up. I have removed the WiFi card and tried to power it on without it but no luck. I put back the one that was in before still no luck. I'm stuck, what can I do? Did some power component get disturbed or something? I'd appreciate any help. Thank you.
Michael Kasede - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 26
Ultimi 30 Giorni: 125
Tutti i Tempi: 4,507
