Salta al contenuto principale
Lenovo ThinkPad T480s WWAN Card Replacement
Cosa ti serve
  1. Lenovo ThinkPad T480s WWAN Card Replacement, Bottom Cover: passo 1, immagine 1 di 2 Lenovo ThinkPad T480s WWAN Card Replacement, Bottom Cover: passo 1, immagine 2 di 2
    • Disable the battery, power down the device, and unplug the power adapter from your device before proceeding/beginning the guide.
    • Loosen the six captive screws with a Phillips #1 screwdriver.
  2. Lenovo ThinkPad T480s WWAN Card Replacement: passo 2, immagine 1 di 3 Lenovo ThinkPad T480s WWAN Card Replacement: passo 2, immagine 2 di 3 Lenovo ThinkPad T480s WWAN Card Replacement: passo 2, immagine 3 di 3
    • Remove the bottom cover with an opening tool.
    • Start from the top edge near the hinge and work your way along the edge until all of the clips are unsnapped.
  3. Lenovo ThinkPad T480s WWAN Card Replacement: passo 3, immagine 1 di 2 Lenovo ThinkPad T480s WWAN Card Replacement: passo 3, immagine 2 di 2
    • Lift the bottom cover off.
  4. Lenovo ThinkPad T480s WWAN Card Replacement, WWAN Card: passo 4, immagine 1 di 3 Lenovo ThinkPad T480s WWAN Card Replacement, WWAN Card: passo 4, immagine 2 di 3 Lenovo ThinkPad T480s WWAN Card Replacement, WWAN Card: passo 4, immagine 3 di 3
    • Flip the cardboard cover off of the WWAN card.
    • Using the spudger, release the coaxial antenna wires from the WWAN card.
    • When reassembling, reattach the blue wire on the left and the orange wire on the right.
  5. Lenovo ThinkPad T480s WWAN Card Replacement: passo 5, immagine 1 di 2 Lenovo ThinkPad T480s WWAN Card Replacement: passo 5, immagine 2 di 2
    • Use a Phillips #1 screwdriver to remove one 2.8mm screw.
  6. Lenovo ThinkPad T480s WWAN Card Replacement: passo 6, immagine 1 di 3 Lenovo ThinkPad T480s WWAN Card Replacement: passo 6, immagine 2 di 3 Lenovo ThinkPad T480s WWAN Card Replacement: passo 6, immagine 3 di 3
    • Slide the WWAN card out from the slot.
Conclusione
Altre 3 persone hanno completato questa guida.
Sarah Westberg
Membro da: 03/11/19
35.086 Reputazione
71 Guide realizzate
iFixit Membro di iFixit
Staff
123 Membri
23.725 Guide realizzate
1Commento della guida
You can also install a secondary SSD into the WWAN slot, but it must fit these requirements:
- SSD size: M.2 2242,
- It must be M+B keyed, and
- (Hypothetically, only the SSD being B keyed is needed, but I haven't seen any NVMe SSDs that are only B-keyed.)
- It must be single-sided, with respect to surface-mount components.
Information came from this video for the ThinkPad T480, but the ThinkPad T480s is similar enough to the ThinkPad T480 for this to work.
Tai Lam - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 30
Ultimi 30 Giorni: 157
Tutti i Tempi: 5,884
