Introduzione
Use this guide to replace the hinges in your Lenovo ThinkPad T480s laptop.
Laptop hinges that are in good condition will allow you to open the laptop lid with ease. The laptop hinges may be malfunctioning if you experience extreme stiffness or looseness when opening and closing the laptop lid. Other symptoms include the lid not shutting completely, the lid not staying open, dislocated hinges, or cracks around the hinges or in the hinges themselves.
Make sure to disable the internal battery, power down your device, and disconnect from any external power sources before you begin.
Cosa ti serve
Use the spudger to disconnect the coaxial cables from the Wi-Fi card and WWAN card.
Using the spudger, pry the LCD bezel up from the edges starting near the hinges.
Use the spudger to remove the internal bezel.
Start at the corner by the hinge and lift the edge of the internal bezel up with the pointed end of the spudger.
Hold the internal bezel with your fingers and work your way around the perimeter of the screen carefully pulling the bezel up.
Remove four 2.9 mm screws from the LCD panel using the Phillips #1 screwdriver.
Use the Phillips #1 screwdriver to remove two 2.8 mm screws from the hinge in the upper right corner.
