Salta al contenuto principale
Lenovo ThinkPad T480s Hall Sensor Replacement
Cosa ti serve
  1. Lenovo ThinkPad T480s Hall Sensor Replacement, Bottom Cover: passo 1, immagine 1 di 2 Lenovo ThinkPad T480s Hall Sensor Replacement, Bottom Cover: passo 1, immagine 2 di 2
    • Disable the battery, power down the device, and unplug the power adapter from your device before proceeding/beginning the guide.
    • Loosen the six captive screws with a Phillips #1 screwdriver.
  2. Lenovo ThinkPad T480s Hall Sensor Replacement: passo 2, immagine 1 di 3 Lenovo ThinkPad T480s Hall Sensor Replacement: passo 2, immagine 2 di 3 Lenovo ThinkPad T480s Hall Sensor Replacement: passo 2, immagine 3 di 3
    • Remove the bottom cover with an opening tool.
    • Start from the top edge near the hinge and work your way along the edge until all of the clips are unsnapped.
  3. Lenovo ThinkPad T480s Hall Sensor Replacement: passo 3, immagine 1 di 2 Lenovo ThinkPad T480s Hall Sensor Replacement: passo 3, immagine 2 di 2
    • Lift the bottom cover off.
  4. Lenovo ThinkPad T480s Hall Sensor Replacement, Battery: passo 4, immagine 1 di 2 Lenovo ThinkPad T480s Hall Sensor Replacement, Battery: passo 4, immagine 2 di 2
    • Use the Phillips #1 screwdriver to remove four 4.5mm screws that hold the battery down to the mid frame.
  5. Lenovo ThinkPad T480s Hall Sensor Replacement: passo 5, immagine 1 di 3 Lenovo ThinkPad T480s Hall Sensor Replacement: passo 5, immagine 2 di 3 Lenovo ThinkPad T480s Hall Sensor Replacement: passo 5, immagine 3 di 3
    • Lift the battery near the connector and remove it from the system.
  6. Lenovo ThinkPad T480s Hall Sensor Replacement, Hall Sensor: passo 6, immagine 1 di 3 Lenovo ThinkPad T480s Hall Sensor Replacement, Hall Sensor: passo 6, immagine 2 di 3 Lenovo ThinkPad T480s Hall Sensor Replacement, Hall Sensor: passo 6, immagine 3 di 3
    • Use a spudger to disconnect the cable from the Hall sensor.
  7. Lenovo ThinkPad T480s Hall Sensor Replacement: passo 7, immagine 1 di 2 Lenovo ThinkPad T480s Hall Sensor Replacement: passo 7, immagine 2 di 2
    • With the Phillips #1 screwdriver, remove one 3.1 mm screw from the sensor.
  8. Lenovo ThinkPad T480s Hall Sensor Replacement: passo 8, immagine 1 di 3 Lenovo ThinkPad T480s Hall Sensor Replacement: passo 8, immagine 2 di 3 Lenovo ThinkPad T480s Hall Sensor Replacement: passo 8, immagine 3 di 3
    • Remove the sensor from the system.
Conclusione
Sarah Westberg
Membro da: 03/11/19
24.106 Reputazione
71 Guide realizzate
iFixit Membro di iFixit
Staff
141 Membri
17.895 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 24
Ultimi 30 Giorni: 117
Tutti i Tempi: 2,574
