Salta al contenuto principale
Lenovo ThinkPad T470 Coin Cell Battery Replacement
Cosa ti serve
  1. Lenovo ThinkPad T470 Coin Cell Battery Replacement, External Battery: passo 1, immagine 1 di 3 Lenovo ThinkPad T470 Coin Cell Battery Replacement, External Battery: passo 1, immagine 2 di 3 Lenovo ThinkPad T470 Coin Cell Battery Replacement, External Battery: passo 1, immagine 3 di 3
    • Before you begin this guide, make sure to disable the internal battery, power down your device, and disconnect from any external power sources.
    • Place the laptop so that the bottom is facing upwards.
    • Slide the latch on the left side of the battery to the left until it clicks in place.
  2. Lenovo ThinkPad T470 Coin Cell Battery Replacement: passo 2, immagine 1 di 3 Lenovo ThinkPad T470 Coin Cell Battery Replacement: passo 2, immagine 2 di 3 Lenovo ThinkPad T470 Coin Cell Battery Replacement: passo 2, immagine 3 di 3
    • Slide the latch on the right side of the battery to the right and hold it in place with your thumb.
    • Use your other hand to slide the battery towards the back of the laptop.
    • Lift the battery up and away from the laptop.
  3. Lenovo ThinkPad T470 Coin Cell Battery Replacement, Bottom Cover: passo 3, immagine 1 di 2 Lenovo ThinkPad T470 Coin Cell Battery Replacement, Bottom Cover: passo 3, immagine 2 di 2
    • Use a Phillips #1 screwdriver to loosen the six captive screws on the bottom cover of the laptop.
  4. Lenovo ThinkPad T470 Coin Cell Battery Replacement: passo 4, immagine 1 di 3 Lenovo ThinkPad T470 Coin Cell Battery Replacement: passo 4, immagine 2 di 3 Lenovo ThinkPad T470 Coin Cell Battery Replacement: passo 4, immagine 3 di 3
    • Use your hands to pull up on the back cover and release the plastic clips starting on the bottom side of the battery compartment.
    • Potential for device damage: Be sure to detach the plastic clips in this area first. You risk cracking the bottom cover if you attempt to detach it from around the edges of the laptop first.
    • Use your hands to pull up on the right side of the bottom cover to release the plastic clips.
    • Use your hands to pull up on the left side of the bottom cover to release the plastic clips.
  5. Lenovo ThinkPad T470 Coin Cell Battery Replacement: passo 5, immagine 1 di 1
    • Remove the bottom cover from the laptop.
    • Disconnect the battery from the board before continuing.
  6. Lenovo ThinkPad T470 Coin Cell Battery Replacement, Coin Cell Battery: passo 6, immagine 1 di 2 Lenovo ThinkPad T470 Coin Cell Battery Replacement, Coin Cell Battery: passo 6, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Use a pair of blunt nose tweezers to pull the white connector out of its socket.
    • This connector may be difficult to remove. You can use a pair of tweezers to gently rock the connector back and forth until it is free from the socket.
  7. Lenovo ThinkPad T470 Coin Cell Battery Replacement: passo 7, immagine 1 di 3 Lenovo ThinkPad T470 Coin Cell Battery Replacement: passo 7, immagine 2 di 3 Lenovo ThinkPad T470 Coin Cell Battery Replacement: passo 7, immagine 3 di 3
    • Grab the wire attached to the coin cell battery, and lift it up and out of the laptop.
Conclusione
Kristen Gismondi
Membro da: 11/12/14
92.538 Reputazione
241 Guide realizzate
iFixit Membro di iFixit
Staff
118 Membri
19.631 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 88
Tutti i Tempi: 4,081
