Introduzione
Use this guide to replace the speakers in your Lenovo ThinkPad T460 laptop.
If your laptop isn’t producing sound, or if the sound is distorted or intermittent, your speakers may be faulty. Be sure to troubleshoot any speaker-related issues before attempting to replace them.
Make sure to disable the internal battery, power down your device, and disconnect from any external power sources before you begin.
Cosa ti serve
Place the laptop so that the bottom is facing upwards.
Slide the latch on the left side of the battery to the left until it clicks in place.
Loosen the eight captive screws in the bottom cover using a Phillips #1 screwdriver.
Insert the flat end of a spudger in between the bottom cover and the rest of the laptop, starting in the lower left corner.
Pry the lower left corner of the bottom cover up by a few millimeters.
Slide the spudger along the bottom of the laptop to release the clips until you reach the lower right corner.
Attrezzo utilizzato in questo passaggio:Tweezers$4.99
Use a pair of blunt nose tweezers to pull the black connector out of its socket.
Use a pair of blunt nose tweezers to pull the white speaker connector out of its socket on the motherboard.
