Salta al contenuto principale
Lenovo ThinkPad T460 Smart Card Reader Cable Replacement
Cosa ti serve
  1. Lenovo ThinkPad T460 Smart Card Reader Cable Replacement, External Battery: passo 1, immagine 1 di 3 Lenovo ThinkPad T460 Smart Card Reader Cable Replacement, External Battery: passo 1, immagine 2 di 3 Lenovo ThinkPad T460 Smart Card Reader Cable Replacement, External Battery: passo 1, immagine 3 di 3
    • Before you begin this guide, make sure to disable the internal battery, power down your device, and disconnect from any external power sources.
    • Place the laptop so that the bottom is facing upwards.
    • Slide the latch on the left side of the battery to the left until it clicks in place.
  2. Lenovo ThinkPad T460 Smart Card Reader Cable Replacement: passo 2, immagine 1 di 3 Lenovo ThinkPad T460 Smart Card Reader Cable Replacement: passo 2, immagine 2 di 3 Lenovo ThinkPad T460 Smart Card Reader Cable Replacement: passo 2, immagine 3 di 3
    • Slide the latch on the right side of the battery to the right and hold it in place with your thumb.
    • Use your other hand to slide the battery towards the back of the laptop.
    • Lift the battery up and away from the laptop.
  3. Lenovo ThinkPad T460 Smart Card Reader Cable Replacement, Bottom Cover: passo 3, immagine 1 di 2 Lenovo ThinkPad T460 Smart Card Reader Cable Replacement, Bottom Cover: passo 3, immagine 2 di 2
    • Loosen the eight captive screws in the bottom cover using a Phillips #1 screwdriver.
  4. Lenovo ThinkPad T460 Smart Card Reader Cable Replacement: passo 4, immagine 1 di 3 Lenovo ThinkPad T460 Smart Card Reader Cable Replacement: passo 4, immagine 2 di 3 Lenovo ThinkPad T460 Smart Card Reader Cable Replacement: passo 4, immagine 3 di 3
    • Insert the flat end of a spudger in between the bottom cover and the rest of the laptop, starting in the lower left corner.
    • Pry the lower left corner of the bottom cover up by a few millimeters.
    • Slide the spudger along the bottom of the laptop to release the clips until you reach the lower right corner.
    • You may hear some snapping noises as the clips are released.
  5. Lenovo ThinkPad T460 Smart Card Reader Cable Replacement: passo 5, immagine 1 di 2 Lenovo ThinkPad T460 Smart Card Reader Cable Replacement: passo 5, immagine 2 di 2
    • Slide the spudger along the right and top sides of the bottom cover to release the clips.
    • Potential for device damage: If the clips do not release easily, check to ensure that the captive screws are fully loosened. Forcing the clips to detach can crack the bottom cover.
  6. Lenovo ThinkPad T460 Smart Card Reader Cable Replacement: passo 6, immagine 1 di 2 Lenovo ThinkPad T460 Smart Card Reader Cable Replacement: passo 6, immagine 2 di 2
    • Use the spudger to pry the upper left corner up by a few millimeters.
    • Pry up the sections of the bottom cover with printed logos of the ports.
    • Potential for device damage: Prying inside the ports themselves can damage your laptop. Be sure to only pry up on the sections of the cover that extend past the ports.
  7. Lenovo ThinkPad T460 Smart Card Reader Cable Replacement: passo 7, immagine 1 di 2 Lenovo ThinkPad T460 Smart Card Reader Cable Replacement: passo 7, immagine 2 di 2
    • Use the spudger to pry up the bottom cover in the lower portion of the external battery compartment by a few millimeters.
  8. Lenovo ThinkPad T460 Smart Card Reader Cable Replacement: passo 8, immagine 1 di 3 Lenovo ThinkPad T460 Smart Card Reader Cable Replacement: passo 8, immagine 2 di 3 Lenovo ThinkPad T460 Smart Card Reader Cable Replacement: passo 8, immagine 3 di 3
    • Use both hands to lift the bottom cover up and away from the laptop.
  9. Lenovo ThinkPad T460 Smart Card Reader Cable Replacement, Internal Battery: passo 9, immagine 1 di 2 Lenovo ThinkPad T460 Smart Card Reader Cable Replacement, Internal Battery: passo 9, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Use a pair of blunt nose tweezers to pull the black connector out of its socket.
    • This connector may be difficult to remove. You can use a pair of tweezers to gently rock the connector back and forth until it is free from the socket.
  10. Lenovo ThinkPad T460 Smart Card Reader Cable Replacement: passo 10, immagine 1 di 2 Lenovo ThinkPad T460 Smart Card Reader Cable Replacement: passo 10, immagine 2 di 2
    • Remove the three 3.7 mm screws from the internal battery using a Phillips #1 screwdriver.
  11. Lenovo ThinkPad T460 Smart Card Reader Cable Replacement: passo 11, immagine 1 di 2 Lenovo ThinkPad T460 Smart Card Reader Cable Replacement: passo 11, immagine 2 di 2
    • Use your hands to lift the battery up and away from the laptop.
  12. Lenovo ThinkPad T460 Smart Card Reader Cable Replacement, Smart Card Reader: passo 12, immagine 1 di 2 Lenovo ThinkPad T460 Smart Card Reader Cable Replacement, Smart Card Reader: passo 12, immagine 2 di 2
    • Remove two 5 mm screws from the speaker in the lower right-hand corner using a Phillips #1 screwdriver.
  13. Lenovo ThinkPad T460 Smart Card Reader Cable Replacement: passo 13, immagine 1 di 3 Lenovo ThinkPad T460 Smart Card Reader Cable Replacement: passo 13, immagine 2 di 3 Lenovo ThinkPad T460 Smart Card Reader Cable Replacement: passo 13, immagine 3 di 3
    • Use your hand to lift the speaker out of its compartment.
    • The speaker's wire will still be secured to the laptop; it is not necessary to remove the wire.
  14. Lenovo ThinkPad T460 Smart Card Reader Cable Replacement: passo 14, immagine 1 di 2 Lenovo ThinkPad T460 Smart Card Reader Cable Replacement: passo 14, immagine 2 di 2
    • Use your fingers to lift the black flap up from the smart card reader cable connector.
  15. Lenovo ThinkPad T460 Smart Card Reader Cable Replacement: passo 15, immagine 1 di 2 Lenovo ThinkPad T460 Smart Card Reader Cable Replacement: passo 15, immagine 2 di 2
    • Use the pointed end of a spudger to open the white clip on the smart card reader connector.
  16. Lenovo ThinkPad T460 Smart Card Reader Cable Replacement: passo 16, immagine 1 di 2 Lenovo ThinkPad T460 Smart Card Reader Cable Replacement: passo 16, immagine 2 di 2
    • Use a pair of blunt nose tweezers to slide the cable out of the connector on the smart card reader.
  17. Lenovo ThinkPad T460 Smart Card Reader Cable Replacement: passo 17, immagine 1 di 2 Lenovo ThinkPad T460 Smart Card Reader Cable Replacement: passo 17, immagine 2 di 2
    • Remove two 3.8 mm screws from the smart card reader bracket using a Phillips #1 screwdriver.
  18. Lenovo ThinkPad T460 Smart Card Reader Cable Replacement: passo 18, immagine 1 di 3 Lenovo ThinkPad T460 Smart Card Reader Cable Replacement: passo 18, immagine 2 di 3 Lenovo ThinkPad T460 Smart Card Reader Cable Replacement: passo 18, immagine 3 di 3
    • Use your fingers to lift the smart card reader bracket up and away from the laptop.
  19. Lenovo ThinkPad T460 Smart Card Reader Cable Replacement: passo 19, immagine 1 di 2 Lenovo ThinkPad T460 Smart Card Reader Cable Replacement: passo 19, immagine 2 di 2
    • Remove two 3.7 mm screws from the smart card reader using a Phillips #1 screwdriver.
  20. Lenovo ThinkPad T460 Smart Card Reader Cable Replacement: passo 20, immagine 1 di 3 Lenovo ThinkPad T460 Smart Card Reader Cable Replacement: passo 20, immagine 2 di 3 Lenovo ThinkPad T460 Smart Card Reader Cable Replacement: passo 20, immagine 3 di 3
    • Use the flat end of a spudger to pry the smart card reader up by a few millimeters.
    • Use your other hand to lift the smart card reader up and away from the laptop.
  21. Lenovo ThinkPad T460 Smart Card Reader Cable Replacement, Smart Card Reader Cable: passo 21, immagine 1 di 3 Lenovo ThinkPad T460 Smart Card Reader Cable Replacement, Smart Card Reader Cable: passo 21, immagine 2 di 3 Lenovo ThinkPad T460 Smart Card Reader Cable Replacement, Smart Card Reader Cable: passo 21, immagine 3 di 3
    • Use your fingers to peel up the smart card reader cable and disconnect it from its socket on the motherboard.
Conclusione
Kristen Gismondi
Membro da: 11/12/14
92.597 Reputazione
241 Guide realizzate
iFixit Membro di iFixit
Staff
118 Membri
19.635 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 1,237
