Salta al contenuto principale
Lenovo ThinkPad T460 RAM Replacement
Cosa ti serve
  1. Lenovo ThinkPad T460 RAM Replacement, External Battery: passo 1, immagine 1 di 3 Lenovo ThinkPad T460 RAM Replacement, External Battery: passo 1, immagine 2 di 3 Lenovo ThinkPad T460 RAM Replacement, External Battery: passo 1, immagine 3 di 3
    • Before you begin this guide, make sure to disable the internal battery, power down your device, and disconnect from any external power sources.
    • Place the laptop so that the bottom is facing upwards.
    • Slide the latch on the left side of the battery to the left until it clicks in place.
  2. Lenovo ThinkPad T460 RAM Replacement: passo 2, immagine 1 di 3 Lenovo ThinkPad T460 RAM Replacement: passo 2, immagine 2 di 3 Lenovo ThinkPad T460 RAM Replacement: passo 2, immagine 3 di 3
    • Slide the latch on the right side of the battery to the right and hold it in place with your thumb.
    • Use your other hand to slide the battery towards the back of the laptop.
    • Lift the battery up and away from the laptop.
  3. Lenovo ThinkPad T460 RAM Replacement, Bottom Cover: passo 3, immagine 1 di 2 Lenovo ThinkPad T460 RAM Replacement, Bottom Cover: passo 3, immagine 2 di 2
    • Loosen the eight captive screws in the bottom cover using a Phillips #1 screwdriver.
  4. Lenovo ThinkPad T460 RAM Replacement: passo 4, immagine 1 di 3 Lenovo ThinkPad T460 RAM Replacement: passo 4, immagine 2 di 3 Lenovo ThinkPad T460 RAM Replacement: passo 4, immagine 3 di 3
    • Insert the flat end of a spudger in between the bottom cover and the rest of the laptop, starting in the lower left corner.
    • Pry the lower left corner of the bottom cover up by a few millimeters.
    • Slide the spudger along the bottom of the laptop to release the clips until you reach the lower right corner.
    • You may hear some snapping noises as the clips are released.
  5. Lenovo ThinkPad T460 RAM Replacement: passo 5, immagine 1 di 2 Lenovo ThinkPad T460 RAM Replacement: passo 5, immagine 2 di 2
    • Slide the spudger along the right and top sides of the bottom cover to release the clips.
    • Potential for device damage: If the clips do not release easily, check to ensure that the captive screws are fully loosened. Forcing the clips to detach can crack the bottom cover.
  6. Lenovo ThinkPad T460 RAM Replacement: passo 6, immagine 1 di 2 Lenovo ThinkPad T460 RAM Replacement: passo 6, immagine 2 di 2
    • Use the spudger to pry the upper left corner up by a few millimeters.
    • Pry up the sections of the bottom cover with printed logos of the ports.
    • Potential for device damage: Prying inside the ports themselves can damage your laptop. Be sure to only pry up on the sections of the cover that extend past the ports.
  7. Lenovo ThinkPad T460 RAM Replacement: passo 7, immagine 1 di 2 Lenovo ThinkPad T460 RAM Replacement: passo 7, immagine 2 di 2
    • Use the spudger to pry up the bottom cover in the lower portion of the external battery compartment by a few millimeters.
  8. Lenovo ThinkPad T460 RAM Replacement: passo 8, immagine 1 di 3 Lenovo ThinkPad T460 RAM Replacement: passo 8, immagine 2 di 3 Lenovo ThinkPad T460 RAM Replacement: passo 8, immagine 3 di 3
    • Use both hands to lift the bottom cover up and away from the laptop.
  9. Lenovo ThinkPad T460 RAM Replacement, RAM: passo 9, immagine 1 di 2 Lenovo ThinkPad T460 RAM Replacement, RAM: passo 9, immagine 2 di 2
    • Use your fingers to lift up the black flap covering the RAM.
  10. Lenovo ThinkPad T460 RAM Replacement: passo 10, immagine 1 di 2 Lenovo ThinkPad T460 RAM Replacement: passo 10, immagine 2 di 2
    • Use your fingers to push the metal clips on either end of the first RAM stick outwards.
    • The RAM stick will pop up by a few millimeters.
  11. Lenovo ThinkPad T460 RAM Replacement: passo 11, immagine 1 di 2 Lenovo ThinkPad T460 RAM Replacement: passo 11, immagine 2 di 2
    • Use your fingers to lift the RAM out of its socket and away from the laptop to remove it.
  12. Lenovo ThinkPad T460 RAM Replacement: passo 12, immagine 1 di 2 Lenovo ThinkPad T460 RAM Replacement: passo 12, immagine 2 di 2
    • Use your fingers to push the metal clips on either end of the second RAM stick outwards.
  13. Lenovo ThinkPad T460 RAM Replacement: passo 13, immagine 1 di 2 Lenovo ThinkPad T460 RAM Replacement: passo 13, immagine 2 di 2
Conclusione
Altre 2 persone hanno completato questa guida.
Kristen Gismondi
Membro da: 11/12/14
92.606 Reputazione
241 Guide realizzate
iFixit Membro di iFixit
Staff
118 Membri
19.636 Guide realizzate
2Commenti sulla guida
NICE CLEAR STEPS . THANKS. Only one user platform conversation mentioned that, of the 2 Ram locations , one is soldered and the other is free to upgrade. Until I read this, I wondered if I could update using both RAM slots . It would be good to add this info . Thanks Again
Bill
Bill Cino - Replica
Just looked at the DEPTH of fixes that you have illustrated. WOW
Bill Cino - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 60
Ultimi 30 Giorni: 323
Tutti i Tempi: 13,202
