Salta al contenuto principale
Lenovo Legion Y520-15IKBN Heatsink Replacement
Cosa ti serve
  1. Lenovo Legion Y520-15IKBN Heatsink Replacement, Base Panel: passo 1, immagine 1 di 2 Lenovo Legion Y520-15IKBN Heatsink Replacement, Base Panel: passo 1, immagine 2 di 2
    • Shut down and unplug your device before proceeding.
    • Remove the thirteen 6.5 mm screws from the base plate using a Phillips #00 screwdriver.
  2. Lenovo Legion Y520-15IKBN Heatsink Replacement: passo 2, immagine 1 di 1
    • Flip the laptop on its side and wedge a spudger between the base panel and chassis, then pry around the perimeter until the base panel releases.
    • To get a better grip you may want to open the laptop slightly.
    • Lift the bottom panel off of the chassis.
    • During reassembly, make sure that the bottom panel clicks back into place on all four sides of the laptop.
  3. Lenovo Legion Y520-15IKBN Heatsink Replacement, Fan: passo 3, immagine 1 di 3 Lenovo Legion Y520-15IKBN Heatsink Replacement, Fan: passo 3, immagine 2 di 3 Lenovo Legion Y520-15IKBN Heatsink Replacement, Fan: passo 3, immagine 3 di 3
    • There is a piece of plastic covering part of the RAM and the fan. You will need to remove this to get to the fan.
    • Unplug the battery then, you will need to remove the four 4 mm screws around the fan using a Phillips #00 screwdriver.
  4. Lenovo Legion Y520-15IKBN Heatsink Replacement: passo 4, immagine 1 di 3 Lenovo Legion Y520-15IKBN Heatsink Replacement: passo 4, immagine 2 di 3 Lenovo Legion Y520-15IKBN Heatsink Replacement: passo 4, immagine 3 di 3
    • Unscrew all the screws then unplug the wires connected to the fan.
    • Once all the wires are unplugged from the fan, move the wires aside to get the fan.
  5. Lenovo Legion Y520-15IKBN Heatsink Replacement: passo 5, immagine 1 di 3 Lenovo Legion Y520-15IKBN Heatsink Replacement: passo 5, immagine 2 di 3 Lenovo Legion Y520-15IKBN Heatsink Replacement: passo 5, immagine 3 di 3
    • Lift the fan out of the laptop body.
  6. Lenovo Legion Y520-15IKBN Heatsink Replacement, Heatsink: passo 6, immagine 1 di 2 Lenovo Legion Y520-15IKBN Heatsink Replacement, Heatsink: passo 6, immagine 2 di 2
    • Use a Phillips #00 screwdriver to remove the five 6.5 mm screws securing the heat sink.
  7. Lenovo Legion Y520-15IKBN Heatsink Replacement: passo 7, immagine 1 di 2 Lenovo Legion Y520-15IKBN Heatsink Replacement: passo 7, immagine 2 di 2
    • Use a spudger to gently pry the heatsink from the board.
Conclusione
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Uriel Meneses
Membro da: 02/08/24
85 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 27
Tutti i Tempi: 253
