Salta al contenuto principale
Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement
Cosa ti serve
  1. Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Back cover removal: passo 1, immagine 1 di 2 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Back cover removal: passo 1, immagine 2 di 2
    • Use a Phillips screwdriver to remove the following ten screws securing the back cover to frame:
    • Six 12.7 mm PH00 screws
    • Four 4.2 mm PH00 screws
  2. Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Release the front clips: passo 2, immagine 1 di 3 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Release the front clips: passo 2, immagine 2 di 3 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Release the front clips: passo 2, immagine 3 di 3
    • Insert the rounded edge of an opening pick between the back cover and the frame in the lower right corner.
  3. Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement: passo 3, immagine 1 di 3 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement: passo 3, immagine 2 di 3 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement: passo 3, immagine 3 di 3
    • Angle the pick to about 45˚.
    • Slide the pick along the front edge to release the clips securing the back cover to the frame.
  4. Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Release the right clips: passo 4, immagine 1 di 3 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Release the right clips: passo 4, immagine 2 di 3 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Release the right clips: passo 4, immagine 3 di 3
    • Insert the rounded edge of an opening pick between the back cover and the frame on the right edge.
    • Angle the pick to about 30˚ and slide down the right edge until you reach the plastic vents on the side.
  5. Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Release the left clips: passo 5, immagine 1 di 3 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Release the left clips: passo 5, immagine 2 di 3 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Release the left clips: passo 5, immagine 3 di 3
    • Repeat the same procedure on the left edge to release the clips.
  6. Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Release the right vent clips: passo 6, immagine 1 di 3 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Release the right vent clips: passo 6, immagine 2 di 3 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Release the right vent clips: passo 6, immagine 3 di 3
    • Position the laptop vertically so you can easily access the plastic vents.
    • Slide the rounded edge of an opening pick between the frame and the plastic vents on the right side near the USB-A port.
    • Rotate the pick so that it is positioned on top of the plastic vents.
  7. Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement: passo 7, immagine 1 di 2 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement: passo 7, immagine 2 di 2
    • Push the pick between the frame and plastic vents.
    • Slide the pick along the top edge of the plastic vents to release the clips.
  8. Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Release the left vent clips: passo 8, immagine 1 di 3 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Release the left vent clips: passo 8, immagine 2 di 3 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Release the left vent clips: passo 8, immagine 3 di 3
    • Slide the rounded edge of an opening pick between the frame and the plastic vents on the left side near the USB-C port.
  9. Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement: passo 9, immagine 1 di 2 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement: passo 9, immagine 2 di 2
  10. Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Remove the back cover: passo 10, immagine 1 di 3 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Remove the back cover: passo 10, immagine 2 di 3 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Remove the back cover: passo 10, immagine 3 di 3
    • Lift the back cover up and remove it from the chassis.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
  11. Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Disconnect the battery: passo 11, immagine 1 di 3 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Disconnect the battery: passo 11, immagine 2 di 3 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Disconnect the battery: passo 11, immagine 3 di 3
    • Use the pointed end of a spudger to push each side of the battery connector to loosen it.
  12. Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement: passo 12, immagine 1 di 2 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement: passo 12, immagine 2 di 2
    • Use the flat end of a spudger to push out and disconnect battery cable.
  13. Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Left SSD removal: passo 13, immagine 1 di 2 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Left SSD removal: passo 13, immagine 2 di 2
    • Use a Phillips screwdriver to remove the three 5.1 mm PH00 screws securing the left SSD shield to the motherboard.
    • During reassembly, make sure the hole on the top of the shield aligns with the post on the chassis.
  14. Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Remove the SSD shield: passo 14, immagine 1 di 3 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Remove the SSD shield: passo 14, immagine 2 di 3 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Remove the SSD shield: passo 14, immagine 3 di 3
    • Grab the SSD shield and lift up to remove it.
  15. Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement: passo 15, immagine 1 di 2 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement: passo 15, immagine 2 di 2
    • Use a Phillips screwdriver to remove the 2.6 mm PH1 screw securing the SSD to the motherboard.
    • The SSD will spring up to about 30˚ when the screw is removed.
  16. Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Remove the left SSD: passo 16, immagine 1 di 3 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Remove the left SSD: passo 16, immagine 2 di 3 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Remove the left SSD: passo 16, immagine 3 di 3
    • Grip the edges of the SSD near the screw indent.
    • Gently pull to remove the SSD.
Conclusione
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Lenovo Legion answers community for help.
Altre 3 persone hanno completato questa guida.
Chayton Ritter
Membro da: 08/21/20
22.506 Reputazione
105 Guide realizzate
Guide Team Membro di Guide Team
Staff
9 Membri
11.374 Guide realizzate
Un commento
@chaytonr What's the maximum supported SSD capacity for Lenovo Legion 5 Pro 16ACH6H? I already have a 1TB SSD on the right slot but can i intall a 2TB SSD on the left slot for a total of 3TB storage?
Ayush Patel - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 46
Ultimi 30 Giorni: 142
Tutti i Tempi: 7,312
