Salta al contenuto principale
Lenovo Ideapad Gaming 3 15ACH6 Left SSD Replacement
Cosa ti serve
  1. Lenovo Ideapad Gaming 3 15ACH6 Left SSD Replacement, Unfasten the lower case: passo 1, immagine 1 di 2 Lenovo Ideapad Gaming 3 15ACH6 Left SSD Replacement, Unfasten the lower case: passo 1, immagine 2 di 2
    • Use a Phillips screwdriver to remove the 10 screws securing the lower case:
    • Six 12 mm screws
    • Four 4.5 mm screws
  2. Lenovo Ideapad Gaming 3 15ACH6 Left SSD Replacement, Insert an opening pick: passo 2, immagine 1 di 2 Lenovo Ideapad Gaming 3 15ACH6 Left SSD Replacement, Insert an opening pick: passo 2, immagine 2 di 2
    • Insert an opening pick between the lower case and the chassis on the front right edge.
  3. Lenovo Ideapad Gaming 3 15ACH6 Left SSD Replacement, Release the clips: passo 3, immagine 1 di 3 Lenovo Ideapad Gaming 3 15ACH6 Left SSD Replacement, Release the clips: passo 3, immagine 2 di 3 Lenovo Ideapad Gaming 3 15ACH6 Left SSD Replacement, Release the clips: passo 3, immagine 3 di 3
    • Slide the pick along the front edge to release the clips securing the lower case.
    • Continue sliding the opening pick along the left and right edges to release the remaining clips.
  4. Lenovo Ideapad Gaming 3 15ACH6 Left SSD Replacement, Remove the lower case: passo 4, immagine 1 di 3 Lenovo Ideapad Gaming 3 15ACH6 Left SSD Replacement, Remove the lower case: passo 4, immagine 2 di 3 Lenovo Ideapad Gaming 3 15ACH6 Left SSD Replacement, Remove the lower case: passo 4, immagine 3 di 3
    • Lift the lower case from the chassis and remove it.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
  5. Lenovo Ideapad Gaming 3 15ACH6 Left SSD Replacement, Disconnect the battery: passo 5, immagine 1 di 3 Lenovo Ideapad Gaming 3 15ACH6 Left SSD Replacement, Disconnect the battery: passo 5, immagine 2 di 3 Lenovo Ideapad Gaming 3 15ACH6 Left SSD Replacement, Disconnect the battery: passo 5, immagine 3 di 3
    • Use the pointed end of a spudger to push each side of the battery connector until it comes out of the socket.
  6. Lenovo Ideapad Gaming 3 15ACH6 Left SSD Replacement, Unfasten the left SSD: passo 6, immagine 1 di 2 Lenovo Ideapad Gaming 3 15ACH6 Left SSD Replacement, Unfasten the left SSD: passo 6, immagine 2 di 2
    • Use a Phillips screwdriver to remove the 2.4 mm screw securing the left SSD.
  7. Lenovo Ideapad Gaming 3 15ACH6 Left SSD Replacement, Remove the SSD: passo 7, immagine 1 di 3 Lenovo Ideapad Gaming 3 15ACH6 Left SSD Replacement, Remove the SSD: passo 7, immagine 2 di 3 Lenovo Ideapad Gaming 3 15ACH6 Left SSD Replacement, Remove the SSD: passo 7, immagine 3 di 3
    • Pull the SSD out of its socket and remove it. Keep the SSD as parallel to the motherboard as possible when pulling on it.
    • Do not pull up at a sharp angle, as this could damage the SSD and the socket.
Conclusione
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Lenovo IdeaPad answers community for help.
Altre 2 persone hanno completato questa guida.
Spencer Day
Membro da: 09/14/22
94.985 Reputazione
662 Guide realizzate
iFixit Membro di iFixit
Staff
118 Membri
19.455 Guide realizzate
3 Commenti
I want do to an ssd upgrade, but I have a 15ihu6 model. Are the instructions the same? And also, the slot is empty. Is there a screw by default? If no, then what length is it?
Kartosh (regeditexe) - Replica
Nevermind, it's 2.4mm, i guess.
Hi! Yes, the left SSD screw is 2.4 mm as you stated. Also make sure your laptop has a standoff screw to put that 2.4 mm screw into (some laptops may not come with one installed).
Spencer Day -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 52
Ultimi 30 Giorni: 197
Tutti i Tempi: 9,913
