Salta al contenuto principale
Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement
Cosa ti serve
  1. Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement, Back Panel: passo 1, immagine 1 di 2 Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement, Back Panel: passo 1, immagine 2 di 2
    • Remove the ten 5 mm Phillips #00 screws that are holding the back panel on.
  2. Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement: passo 2, immagine 1 di 3 Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement: passo 2, immagine 2 di 3 Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement: passo 2, immagine 3 di 3
    • Use a spudger to pry open the back case at the two hinge cutouts.
    • Gently use the plastic opening tool around the edges of the laptop to pry up the clips holding the rest of the back panel.
  3. Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement: passo 3, immagine 1 di 2 Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement: passo 3, immagine 2 di 2
    • Once all the clips have been disengaged, lift off the back cover.
  4. Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement, Battery Disconnect: passo 4, immagine 1 di 3 Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement, Battery Disconnect: passo 4, immagine 2 di 3 Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement, Battery Disconnect: passo 4, immagine 3 di 3
    • Using your fingers, grasp the entire bundle of wires to pull the battery cable from its connector. This will cut off power to the motherboard.
    • Be sure to apply even pressure across the wires and connector to not damage the battery cable.
  5. Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement, M.2 SSD: passo 5, immagine 1 di 3 Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement, M.2 SSD: passo 5, immagine 2 di 3 Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement, M.2 SSD: passo 5, immagine 3 di 3
    • Remove the single 2.9 mm screw holding down the solid state drive with a Phillips #0 screwdriver.
    • The SSD will rise to rest at an angle once the screw is removed.
  6. Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement: passo 6, immagine 1 di 3 Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement: passo 6, immagine 2 di 3 Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement: passo 6, immagine 3 di 3
    • Pull the solid state drive out of its port to the right at a similar angle to which it rests.
    • Remove the SSD from the device.
Conclusione
Austin Blakely
Membro da: 03/11/19
16.971 Reputazione
52 Guide realizzate
iFixit Membro di iFixit
Community
137 Membri
17.047 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 10
Ultimi 7 Giorni: 61
Ultimi 30 Giorni: 285
Tutti i Tempi: 3,111
