Salta al contenuto principale
Lenovo Essential B570 RAM Replacement
Cosa ti serve
    1. Lenovo Essential B570 RAM Replacement, Battery: passo 1, immagine 1 di 1
      • Turn over laptop.
      • Switch open the left battery lock.
      • If you are replacing inner components of the laptop, it is recommended to remove the battery first to avoid damage to the laptop.
      Chiedi a FixBot
      Aggiungi Commento
    2. Lenovo Essential B570 RAM Replacement: passo 2, immagine 1 di 1
      • Hold the right battery lock open with one hand while removing the battery itself with the other.
      Chiedi a FixBot
      Aggiungi Commento
    1. Lenovo Essential B570 RAM Replacement, Back Panel: passo 3, immagine 1 di 1
      • Loosen the five Philips screws that secure the panel.
      • The screws do not actually fully remove from the panel. Loosening them as much as you can will be enough to disconnect them from the laptop.
      Chiedi a FixBot
      Aggiungi Commento
    2. Lenovo Essential B570 RAM Replacement: passo 4, immagine 1 di 3 Lenovo Essential B570 RAM Replacement: passo 4, immagine 2 di 3 Lenovo Essential B570 RAM Replacement: passo 4, immagine 3 di 3
      • Prop open the cover with a plastic opening tool.
      • If the cover does not come off easily, do not force it. Make sure all screws are loosened.
      Chiedi a FixBot
      Aggiungi Commento
    1. Lenovo Essential B570 RAM Replacement, RAM: passo 5, immagine 1 di 2 Lenovo Essential B570 RAM Replacement, RAM: passo 5, immagine 2 di 2
      • Release your RAM by pulling its locks away from one another.
      Chiedi a FixBot
      Aggiungi Commento
    2. Lenovo Essential B570 RAM Replacement: passo 6, immagine 1 di 2 Lenovo Essential B570 RAM Replacement: passo 6, immagine 2 di 2
      • Remove RAM by carefully pulling it away from its socket.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 8
Ultimi 30 giorni: 27
Tutti i Tempi: 1,305
