Salta al contenuto principale
Lefant M210 Battery Replacement
Cosa ti serve
    1. Lefant M210 Battery Replacement, Brush: passo 1, immagine 1 di 2 Lefant M210 Battery Replacement, Brush: passo 1, immagine 2 di 2
      • Turn off the Lefant M210 and disconnect it from the charging dock.
      • Flip the unit over so the bottom faces upward.
      • Locate the circular brush assemblies on the left and right sides of the underside.
      • Place the unit on a clean, flat surface to prevent scratching.
      Chiedi a FixBot
      Aggiungi Commento
    2. Lefant M210 Battery Replacement: passo 2, immagine 1 di 3 Lefant M210 Battery Replacement: passo 2, immagine 2 di 3 Lefant M210 Battery Replacement: passo 2, immagine 3 di 3
      • Insert the iFixit Opening Tool (or similar pry tool) under the circular edge of the brush assembly.
      • Apply gentle downward pressure on the opposite end of the tool to lever the brush component out of its housing.
      • Remove the brush assembly completely and set it aside.
      • If replacing both brush assemblies, repeat this process on the other side.
      • Avoid using excessive force, which may damage the mounting clips.
      Chiedi a FixBot
      Aggiungi Commento
      • Position the new brush assembly above the square mounting peg.
      • Align the square cavity on the bottom of the brush with the corresponding square peg in the vacuum housing.
      • Press down firmly on the brush assembly until you hear or feel it click into place.
      • Gently tug on the brush to verify it is securely seated.
      • The brush should sit flush with the housing and not move when pulled gently.
      Chiedi a FixBot
      Aggiungi Commento
    1. Lefant M210 Battery Replacement, Wheel Assembly: passo 4, immagine 1 di 1
      • Use a Phillips screwdriver to remove four screws near each wheel.
      Chiedi a FixBot
      Aggiungi Commento
    2. Lefant M210 Battery Replacement: passo 5, immagine 1 di 2 Lefant M210 Battery Replacement: passo 5, immagine 2 di 2
      • Remove the plastic cover next to each wheel.
      • Grip both sides of the wheel and pull upwards.
      • The wheels of the device require some force to remove.
      • Don't pull the wheels too hard as they are attached to cables and may be damaged if yanked.
      Chiedi a FixBot
      Aggiungi Commento
    3. Lefant M210 Battery Replacement: passo 6, immagine 1 di 3 Lefant M210 Battery Replacement: passo 6, immagine 2 di 3 Lefant M210 Battery Replacement: passo 6, immagine 3 di 3
      • Hold the wheel up and detach the connector to release it from the device.
      Chiedi a FixBot
      Aggiungi Commento
    1. Lefant M210 Battery Replacement, Dustbin Filters: passo 7, immagine 1 di 1
      • Open the dustbin compartment.
      Chiedi a FixBot
      Aggiungi Commento
    2. Lefant M210 Battery Replacement: passo 8, immagine 1 di 2 Lefant M210 Battery Replacement: passo 8, immagine 2 di 2
      • With your hands, gently pull the dustbin to remove it from its compartment.
      Chiedi a FixBot
      Aggiungi Commento
    3. Lefant M210 Battery Replacement: passo 9, immagine 1 di 1
      • With your hands, pull off the filter compartment from the dustbin.
      Chiedi a FixBot
      Aggiungi Commento
    4. Lefant M210 Battery Replacement: passo 10, immagine 1 di 1
      • Pull off the filter from the filter compartment.
      Chiedi a FixBot
      Aggiungi Commento
    1. Lefant M210 Battery Replacement, Battery: passo 11, immagine 1 di 1
      • Use a Phillips #1 screwdriver to remove the six screws around the bottom edge of the device.
      Chiedi a FixBot
      Aggiungi Commento
    2. Lefant M210 Battery Replacement: passo 12, immagine 1 di 2 Lefant M210 Battery Replacement: passo 12, immagine 2 di 2
      • Carefully flip the vacuum back right-side-up, making sure you're holding it all together so that the bottom portion doesn't fall out.
      • Rotate the vacuum so that the Lefant logo is facing you.
      • Carefully lift the white cover of the vacuum, opening it like a laptop, from front to back.
      • Rest the open cover something stable, like a wall.
      Chiedi a FixBot
      Aggiungi Commento
    3. Lefant M210 Battery Replacement: passo 13, immagine 1 di 2 Lefant M210 Battery Replacement: passo 13, immagine 2 di 2
      • Use a Phillips #1 screwdriver to remove the three screws securing the motherboard to the device.
      Chiedi a FixBot
      Aggiungi Commento
    4. Lefant M210 Battery Replacement: passo 14, immagine 1 di 1
      • Carefully lift the motherboard, ensuring you don't rip any cables that are connected to it.
      • The battery should be under the motherboard.
      Chiedi a FixBot
      Aggiungi Commento
    5. Lefant M210 Battery Replacement: passo 15, immagine 1 di 2 Lefant M210 Battery Replacement: passo 15, immagine 2 di 2
      • Push the two retaining clips away from the battery while pulling the battery up from the tabs attached to it to free it.
      • Retaining clips
      • Battery tabs
      • Work on freeing one side at a time so that it's easier to free the battery.
      Chiedi a FixBot
      Aggiungi Commento
    6. Lefant M210 Battery Replacement: passo 16, immagine 1 di 1
      • When the battery is free from it's housing, lift it out completely using its pull tabs.
      Chiedi a FixBot
      Aggiungi Commento
    7. Lefant M210 Battery Replacement: passo 17, immagine 1 di 2 Lefant M210 Battery Replacement: passo 17, immagine 2 di 2
      • Locate the battery connection wire and carefully pull apart the connection.
      • Pinch the motherboard's wire connector and pull the connection apart.
      • The connection is secured by a clothespin-like mechanism.
      • When you replace your battery with a new one, allow the robot vacuum to fully charge for a few hours before using it again.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 5 persone hanno completato questa guida.
Darien Amador
Membro da: 09/09/24
300 Reputazione
Una guida realizzata
CSU Los Angeles, Team 2-4, Kershman Fall 2024 Membro di CSU Los Angeles, Team 2-4, Kershman Fall 2024
CSULA-KERSHMAN-F24S2G4
4 Membri
13 guide realizzate
5Commenti sulla guida
Great guide! Any knowledge on how or why mine beeps twice even when it is on the ground?
Jonathan Manuel - Rispondi Condividi
Thank you for the helpful guide, however, after replacing my battery, it definitely has a much shorter lifespan, and it is unable to find the charger before it dies.
Tee Cee - Rispondi Condividi
I thought it was because I needed a new battery. My stops about 1min after start. When I put it back to the charger it indicates battery charged by showing the blue light. Still after 1 min of operation it dies. That's the reason why i want to replace the battery. Is that what yours is doing too even after replacing the battery?
Zed - Rispondi Condividi
Thanks for the guide.
As for those that stumble upon this, mind that ******if you only want to access the battery, steps 10 to 16 are the only on you need.
Sylvain “Neoblasphem” Mourot - Rispondi Condividi
Bought new batt, installed it and same problem. Red light, not charging. I guess it’s dead for good.
Kelly In Cali - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 34
Ultimi 7 giorni: 242
Ultimi 30 giorni: 934
Tutti i Tempi: 15,614
