Salta al contenuto principale
LeapFrog Scribble and Write Display Screen Replacement
Cosa ti serve
    1. LeapFrog Scribble and Write Display Screen Replacement, Display Screen: passo 1, immagine 1 di 2 LeapFrog Scribble and Write Display Screen Replacement, Display Screen: passo 1, immagine 2 di 2
      • Turn your toy over.
      • Use a Phillips screwdriver to remove the nine case screws from the back of the toy.
      • Be careful to keep track of the screws.
      Chiedi a FixBot
      Aggiungi Commento
    2. LeapFrog Scribble and Write Display Screen Replacement: passo 2, immagine 1 di 1
      • Carefully remove the back of the toy..
      Chiedi a FixBot
      Aggiungi Commento
    3. LeapFrog Scribble and Write Display Screen Replacement: passo 3, immagine 1 di 2 LeapFrog Scribble and Write Display Screen Replacement: passo 3, immagine 2 di 2
      • Use a Philips screwdriver to remove the two screws attached to the motherboard.
      • Remove the motherboard.
      Chiedi a FixBot
      Aggiungi Commento
    4. LeapFrog Scribble and Write Display Screen Replacement: passo 4, immagine 1 di 2 LeapFrog Scribble and Write Display Screen Replacement: passo 4, immagine 2 di 2
      • Remove the screen.
      • Remove the two pins from the bottom of the screen.
      Chiedi a FixBot
      Aggiungi Commento
    5. LeapFrog Scribble and Write Display Screen Replacement: passo 5, immagine 1 di 1
      • Use a Phillips screwdriver to remove the screw from the green clip that holds the two screen layers together.
      Chiedi a FixBot
      Aggiungi Commento
    6. LeapFrog Scribble and Write Display Screen Replacement: passo 6, immagine 1 di 2 LeapFrog Scribble and Write Display Screen Replacement: passo 6, immagine 2 di 2
      • Separate the blue and the white films.
      • Clean both films with paper towel.
      • Make sure there are no dirty spots before putting the films back together.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Shang
Membro da: 02/10/16
328 Reputazione
3 guide realizzate
USF Tampa, Team 1-5, Nance Spring 2016 Membro di USF Tampa, Team 1-5, Nance Spring 2016
USFT-NANCE-S16S1G5
3 Membri
10 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 4
Ultimi 7 giorni: 16
Ultimi 30 giorni: 51
Tutti i Tempi: 5,122
