Salta al contenuto principale
LeapFrog LeapPad2 Explorer Back Camera Replacement
Cosa ti serve
  1. LeapFrog LeapPad2 Explorer Back Camera Replacement, Battery: passo 1, immagine 1 di 2 LeapFrog LeapPad2 Explorer Back Camera Replacement, Battery: passo 1, immagine 2 di 2
    • Before disassembling your LeapPad, ensure your device is shut off.
    • Push outward on the plastic side panels to remove and reveal battery.
    • The panels should detach fully from the main device.
    Chiedi a FixBot
    Aggiungi Commento
  2. LeapFrog LeapPad2 Explorer Back Camera Replacement: passo 2, immagine 1 di 3 LeapFrog LeapPad2 Explorer Back Camera Replacement: passo 2, immagine 2 di 3 LeapFrog LeapPad2 Explorer Back Camera Replacement: passo 2, immagine 3 di 3
    • Push down from the positive end of the battery towards the negative end to pry the battery up out of its dispenser.
    • Remove all four AA alkaline batteries from the device.
    Chiedi a FixBot
    Aggiungi Commento
  3. LeapFrog LeapPad2 Explorer Back Camera Replacement, Back Cover: passo 3, immagine 1 di 2 LeapFrog LeapPad2 Explorer Back Camera Replacement, Back Cover: passo 3, immagine 2 di 2
    • This step will void your device warranty.
    • Remove the following screws securing the back cover to the main device:
    • Two 10.0 mm Phillips screws
    • Four 4.0 mm Phillips screws
    • Three 3.0 mm Phillips screws
    Chiedi a FixBot
    Aggiungi Commento
  4. LeapFrog LeapPad2 Explorer Back Camera Replacement: passo 4, immagine 1 di 3 LeapFrog LeapPad2 Explorer Back Camera Replacement: passo 4, immagine 2 di 3 LeapFrog LeapPad2 Explorer Back Camera Replacement: passo 4, immagine 3 di 3
    • Insert a plastic opening tool into the seam between the front and rear covers to detach the back cover from the rest of the device.
    • Move the plastic opening tool around the perimeter of the LeapPad2.
    • Lift up and remove the rear case from the tablet.
    • A butter knife can help when prying the device.
    Chiedi a FixBot
    Aggiungi Commento
  5. LeapFrog LeapPad2 Explorer Back Camera Replacement, Back Camera: passo 5, immagine 1 di 2 LeapFrog LeapPad2 Explorer Back Camera Replacement, Back Camera: passo 5, immagine 2 di 2
    • Locate the back camera below the game cartridge.
    Chiedi a FixBot
    Aggiungi Commento
  6. LeapFrog LeapPad2 Explorer Back Camera Replacement: passo 6, immagine 1 di 2 LeapFrog LeapPad2 Explorer Back Camera Replacement: passo 6, immagine 2 di 2
    • To safely remove the ribbon cable, first you must pull up the retaining flap.
    • Removing or reinserting the cable by brute force can damage it.
    Chiedi a FixBot
    Aggiungi Commento
  7. LeapFrog LeapPad2 Explorer Back Camera Replacement: passo 7, immagine 1 di 2 LeapFrog LeapPad2 Explorer Back Camera Replacement: passo 7, immagine 2 di 2
    • Pull up using a thin plastic tool to disconnect the ribbon connecting the camera to the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  8. LeapFrog LeapPad2 Explorer Back Camera Replacement: passo 8, immagine 1 di 1
    • Gently remove the back camera from your motherboard by pushing the black casing away from the camera.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Nupur Garg
Membro da: 04/12/14
867 Reputazione
7 guide realizzate
Cal Poly, Team 8-10, Regan Spring 2014 Membro di Cal Poly, Team 8-10, Regan Spring 2014
CPSU-REGAN-S14S8G10
4 Membri
16 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 24
Tutti i Tempi: 1,509
