Salta al contenuto principale
Le Pan S Volume Rocker Replacement
Cosa ti serve
    1. Le Pan S Volume Rocker Replacement, Battery: passo 1, immagine 1 di 1
      • Remove the two 3.5 mm Phillips #00 screws that are covered by the micro SD port.
      • This cover is adjacent to the volume button on the side of the Le Pan S.
      Chiedi a FixBot
      Aggiungi Commento
    2. Le Pan S Volume Rocker Replacement: passo 2, immagine 1 di 2 Le Pan S Volume Rocker Replacement: passo 2, immagine 2 di 2
      • Insert the spudger between the front and back panel in order to pry them apart.
      • Do this beside the volume button and the micro SD cover.
      • Pry open the rest of the Le Pan S by dragging the spudger across the side.
      Chiedi a FixBot
      Aggiungi Commento
    3. Le Pan S Volume Rocker Replacement: passo 3, immagine 1 di 1
      • Once the front and back faces are completely separated, remove the back cover to reveal the inside components.
      Chiedi a FixBot
      Aggiungi Commento
    4. Le Pan S Volume Rocker Replacement: passo 4, immagine 1 di 2 Le Pan S Volume Rocker Replacement: passo 4, immagine 2 di 2
      • Disconnect the battery from the circuitry and lay it out of the way.
      • The best method to complete this is to pull the bundled cable connector out with your hands. Pull towards the wires and away from the electrical board. Use the spudger to further coax the cable out.
      • If you are replacing your battery, make sure to dispose of it properly.
      Chiedi a FixBot
      Aggiungi Commento
    1. Le Pan S Volume Rocker Replacement, Volume Rocker: passo 5, immagine 1 di 1
      • Remove the four 2.5 mm Phillips #00 head screws from the circuit board near the top of the tablet.
      Chiedi a FixBot
      Aggiungi Commento
    2. Le Pan S Volume Rocker Replacement: passo 6, immagine 1 di 1
      • Pull out the volume rocker by carefully moving it side to side with your fingers.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
IUPUI, Team 2-1, Harley Fall 2015 Membro di IUPUI, Team 2-1, Harley Fall 2015
IUPUI-HARLEY-F15S2G1
5 Membri
10 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 6
Ultimi 30 giorni: 22
Tutti i Tempi: 532
