Salta al contenuto principale
Le Pan S Camera Replacement
Cosa ti serve
    1. Le Pan S Camera Replacement, Battery: passo 1, immagine 1 di 1
      • Remove the two 3.5 mm Phillips #00 screws that are covered by the micro SD port.
      • This cover is adjacent to the volume button on the side of the Le Pan S.
      Chiedi a FixBot
      Aggiungi Commento
    2. Le Pan S Camera Replacement: passo 2, immagine 1 di 2 Le Pan S Camera Replacement: passo 2, immagine 2 di 2
      • Insert the spudger between the front and back panel in order to pry them apart.
      • Do this beside the volume button and the micro SD cover.
      • Pry open the rest of the Le Pan S by dragging the spudger across the side.
      Chiedi a FixBot
      Aggiungi Commento
    3. Le Pan S Camera Replacement: passo 3, immagine 1 di 1
      • Once the front and back faces are completely separated, remove the back cover to reveal the inside components.
      Chiedi a FixBot
      Aggiungi Commento
    4. Le Pan S Camera Replacement: passo 4, immagine 1 di 2 Le Pan S Camera Replacement: passo 4, immagine 2 di 2
      • Disconnect the battery from the circuitry and lay it out of the way.
      • The best method to complete this is to pull the bundled cable connector out with your hands. Pull towards the wires and away from the electrical board. Use the spudger to further coax the cable out.
      • If you are replacing your battery, make sure to dispose of it properly.
      Chiedi a FixBot
      Aggiungi Commento
    1. Le Pan S Camera Replacement, Camera: passo 5, immagine 1 di 1
      • Remove the four 3.5 mm Phillips #00 screws from the circuit board near the bottom of the tablet.
      Chiedi a FixBot
      Aggiungi Commento
    2. Le Pan S Camera Replacement: passo 6, immagine 1 di 1
      • Lift and pull the volume rocker up so it is out of the way of the camera.
      Chiedi a FixBot
      Aggiungi Commento
    3. Le Pan S Camera Replacement: passo 7, immagine 1 di 2 Le Pan S Camera Replacement: passo 7, immagine 2 di 2
      • Remove the zero insertion force connector (ZIF) by using a plastic opening tool, spudger, or fingernail to lift retaining flap.
      Chiedi a FixBot
      Aggiungi Commento
    4. Le Pan S Camera Replacement: passo 8, immagine 1 di 2 Le Pan S Camera Replacement: passo 8, immagine 2 di 2
      • Slightly lift up the green electrical board and pull out the camera.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Tyler Ziliak
Membro da: 09/17/15
110 Reputazione
Una guida realizzata
IUPUI, Team 2-1, Harley Fall 2015 Membro di IUPUI, Team 2-1, Harley Fall 2015
IUPUI-HARLEY-F15S2G1
5 Membri
10 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 4
Ultimi 30 giorni: 14
Tutti i Tempi: 490
