Salta al contenuto principale
Le Pan S Battery Replacement
Cosa ti serve
    1. Le Pan S Battery Replacement, Battery: passo 1, immagine 1 di 1
      • Remove the two 3.5 mm Phillips #00 screws that are covered by the micro SD port.
      • This cover is adjacent to the volume button on the side of the Le Pan S.
      Chiedi a FixBot
      Aggiungi Commento
    2. Le Pan S Battery Replacement: passo 2, immagine 1 di 2 Le Pan S Battery Replacement: passo 2, immagine 2 di 2
      • Insert the spudger between the front and back panel in order to pry them apart.
      • Do this beside the volume button and the micro SD cover.
      • Pry open the rest of the Le Pan S by dragging the spudger across the side.
      Chiedi a FixBot
      Aggiungi Commento
    3. Le Pan S Battery Replacement: passo 3, immagine 1 di 1
      • Once the front and back faces are completely separated, remove the back cover to reveal the inside components.
      Chiedi a FixBot
      Aggiungi Commento
    4. Le Pan S Battery Replacement: passo 4, immagine 1 di 2 Le Pan S Battery Replacement: passo 4, immagine 2 di 2
      • Disconnect the battery from the circuitry and lay it out of the way.
      • The best method to complete this is to pull the bundled cable connector out with your hands. Pull towards the wires and away from the electrical board. Use the spudger to further coax the cable out.
      • If you are replacing your battery, make sure to dispose of it properly.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
Maria Dole
Membro da: 09/17/15
395 Reputazione
3 guide realizzate
IUPUI, Team 2-1, Harley Fall 2015 Membro di IUPUI, Team 2-1, Harley Fall 2015
IUPUI-HARLEY-F15S2G1
5 Membri
10 guide realizzate
5Commenti sulla guida
where can I purchase a battery for a tc978
Timothy - Rispondi Condividi
Hi Timothy, Did you ever find out where to purchase a battery for your Le Pan S tablet?
jatrussel - Rispondi Condividi
But what do I do when it's not the battery, but is the charger is so loose in the tablet, it won;t charge. Once in a while, I can get it to come on if I happened to hold the charger just right. So disgusting. Can this be fixed.? i have purchased two LePans and neither will charge.
cdboers - Rispondi Condividi
Where can I purchase the battery needed?????????????????
Thank you Maria!
Easy to take apart. Disconnected/reconnected battery and voila!
All good.
Be well.
Den E
Denny Ehlers - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 9
Ultimi 30 giorni: 44
Tutti i Tempi: 5,916
