Salta al contenuto principale
LG Voyager Keyboard Replacement
Cosa ti serve
  1. LG Voyager Keyboard Replacement, Battery: passo 1, immagine 1 di 1
    • Turn over the phone so the front screen is facing down and the back side is up.
    Chiedi a FixBot
    Aggiungi Commento
  2. LG Voyager Keyboard Replacement: passo 2, immagine 1 di 1
    • Pull down on the button at the bottom of the phone. The battery will pop up and can then be safely removed.
    Chiedi a FixBot
    Aggiungi Commento
  3. LG Voyager Keyboard Replacement: passo 3, immagine 1 di 1
    • To install the new battery, position the battery so that the three small metal contacts of the battery are facing the three metal contacts of the phone
    • Insert the top of the battery, with the two plastic tabs, into their respective holes in the top
    • Then press down on the bottom of the battery and it should snap into place
    Chiedi a FixBot
    Aggiungi Commento
  4. LG Voyager Keyboard Replacement, Keyboard: passo 4, immagine 1 di 2 LG Voyager Keyboard Replacement, Keyboard: passo 4, immagine 2 di 2
    • First remove the rubber stoppers covering the screws on the back of the phone by prying them up and away from the phone.
    Chiedi a FixBot
    Aggiungi Commento
  5. LG Voyager Keyboard Replacement: passo 5, immagine 1 di 2 LG Voyager Keyboard Replacement: passo 5, immagine 2 di 2
    • Remove the 3.61mm length, Phillips screws from the back of the phone using the #00 screwdriver.
    Chiedi a FixBot
    Aggiungi Commento
  6. LG Voyager Keyboard Replacement: passo 6, immagine 1 di 2 LG Voyager Keyboard Replacement: passo 6, immagine 2 di 2
    • Now pry open the back of the phone.
    • Make sure that you use the plastic opening tool to go around the entire phone to help open the phone.
    Chiedi a FixBot
    Aggiungi Commento
  7. LG Voyager Keyboard Replacement: passo 7, immagine 1 di 2 LG Voyager Keyboard Replacement: passo 7, immagine 2 di 2
    • Carefully separate the keyboard from the top of the phone.
    • Be careful not to break the ribbon cable.
    Chiedi a FixBot
    Aggiungi Commento
  8. LG Voyager Keyboard Replacement: passo 8, immagine 1 di 1
    • Detach the keyboard from the phone by taking off the little metal latches.
    • When replacing the old keyboard with a new one you will have to solder the metal latches to the new board.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Cal Poly, Team 17-26, Amido Spring 2012 Membro di Cal Poly, Team 17-26, Amido Spring 2012
CPSU-AMIDO-S12S17G26
4 Membri
4 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 5
Ultimi 30 giorni: 22
Tutti i Tempi: 674
