Salta al contenuto principale
LG VX5600 Plastic Screen Protector Replacement
Cosa ti serve
  1. LG VX5600 Plastic Screen Protector Replacement, Battery: passo 1, immagine 1 di 2 LG VX5600 Plastic Screen Protector Replacement, Battery: passo 1, immagine 2 di 2
    • Hold your phone with the back casing facing you and the bottom of the phone towards the sky.
    • Push down on the cover and slide down to remove. You should only have to apply minimal pressure.
    Chiedi a FixBot
    Aggiungi Commento
  2. LG VX5600 Plastic Screen Protector Replacement: passo 2, immagine 1 di 2 LG VX5600 Plastic Screen Protector Replacement: passo 2, immagine 2 di 2
    • Insert your finger into the small indentation above the battery.
    • Push down on the battery and pull it away from the phone; it will pop out.
    Chiedi a FixBot
    Aggiungi Commento
  3. LG VX5600 Plastic Screen Protector Replacement, Plastic Screen Protector: passo 3, immagine 1 di 1
    Strumento utilizzato in questo passaggio:
    • Use tweezers to remove the two rubber covers found at the left and right corners below the inside screen.
    Chiedi a FixBot
    Aggiungi Commento
  4. LG VX5600 Plastic Screen Protector Replacement: passo 4, immagine 1 di 1
    • Grasp the phone and rotate it 90 degrees counterclockwise for a better grip.
    • Unscrew the two 3.0-mm Phillips #000 screws, found under the rubber covers at the bottom left and right corners.
    • Some of the pictures show the bottom of the phone disassembled. It is unneccessary to disassemble the bottom of the phone for this guide.
    Chiedi a FixBot
    Aggiungi Commento
  5. LG VX5600 Plastic Screen Protector Replacement: passo 5, immagine 1 di 2 LG VX5600 Plastic Screen Protector Replacement: passo 5, immagine 2 di 2
    • Hold the opened phone upright.
    • Use the spudger to pry around the edges of the phone and detach the tabs.
    • Make sure all the tabs around the grey cover are detached. They are located on the top and on both sides of the screen.
    Chiedi a FixBot
    Aggiungi Commento
  6. LG VX5600 Plastic Screen Protector Replacement: passo 6, immagine 1 di 1
    • Use your finger to lift up the grey plastic cover.
    • Use the tweezers to grasp the plastic screen, and pull the plastic screen protector up and out of the phone.
    • The plastic screen protector is adhered with glue to the back of the phone, so a little force is required to remove it.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 4
Ultimi 30 giorni: 33
Tutti i Tempi: 797
