Salta al contenuto principale
LG Tribute Touchscreen Replacement
Cosa ti serve
  1. LG Tribute Touchscreen Replacement, Battery: passo 1, immagine 1 di 2 LG Tribute Touchscreen Replacement, Battery: passo 1, immagine 2 di 2
    • Use the plastic opening tool to pry off the back cover.
    Chiedi a FixBot
    Aggiungi Commento
  2. LG Tribute Touchscreen Replacement: passo 2, immagine 1 di 1
    • Lift the battery out of place.
    • When replacing the battery, the (+) and (-) symbols must match up with the phone's charging nodes.
    Chiedi a FixBot
    Aggiungi Commento
  3. LG Tribute Touchscreen Replacement, Mid-panel: passo 3, immagine 1 di 2 LG Tribute Touchscreen Replacement, Mid-panel: passo 3, immagine 2 di 2
    • Remove eight 4mm screws using a Phillips head 000 screwdriver (PH000).
    Chiedi a FixBot
    Aggiungi Commento
  4. LG Tribute Touchscreen Replacement: passo 4, immagine 1 di 2 LG Tribute Touchscreen Replacement: passo 4, immagine 2 di 2
    • Use a plastic opening tool to loosen the tabs around the edge of the phone.
    • Inserting a thin piece of plastic will help prevent opened tabs from locking back into place.
    • This step can be frustrating, but requires patience. Avoid the temptation to pry the panel loose. Using excessive force may break the delicate tabs.
    Chiedi a FixBot
    Aggiungi Commento
  5. LG Tribute Touchscreen Replacement, Motherboard: passo 5, immagine 1 di 1
    • Use a plastic opening tool to disconnect the touchscreen from the motherboard.
    • The motherboard will be completely free from the front panel after this step.
    Chiedi a FixBot
    Aggiungi Commento
  6. LG Tribute Touchscreen Replacement, Touchscreen: passo 6, immagine 1 di 3 LG Tribute Touchscreen Replacement, Touchscreen: passo 6, immagine 2 di 3 LG Tribute Touchscreen Replacement, Touchscreen: passo 6, immagine 3 di 3
    • Use a thin piece of plastic to carefully peel the frame away from the touchscreen glass.
    • When the frame is completely free, remove all of the glue.
    • When removing the glue, be sure the speaker grill and LED light spacer do not dislodge.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 12 persone hanno completato questa guida.
4Commenti sulla guida
thank you for all ypu work at web site
salah dholman - Rispondi Condividi
Can you peel away lens without taking apart ?
mikeknapik1 - Rispondi Condividi
Must I remove the motherboard to replace the front cover with the glass?
Deb Schell - Rispondi Condividi
I messed up the speaker is there a way to replace or fix it
bigestbabybratt - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 21
Ultimi 30 giorni: 51
Tutti i Tempi: 16,574
