Salta al contenuto principale
LG TP 1100 Microphone Replacement
Cosa ti serve
  1. LG TP 1100 Microphone Replacement, Microphone: passo 1, immagine 1 di 1
    • Hold antenna between your fingers and unscrew in a counterclockwise direction.
    Chiedi a FixBot
    Aggiungi Commento
  2. LG TP 1100 Microphone Replacement: passo 2, immagine 1 di 1
    • You will remove antenna by pulling it in an upward motion away from the socket.
    Chiedi a FixBot
    Aggiungi Commento
  3. LG TP 1100 Microphone Replacement: passo 3, immagine 1 di 1
    • Turn phone so that the back is facing you.
    Chiedi a FixBot
    Aggiungi Commento
  4. LG TP 1100 Microphone Replacement: passo 4, immagine 1 di 1
    • Use your thumb to pull the tab in an upward motion to release the battery.
    Chiedi a FixBot
    Aggiungi Commento
  5. LG TP 1100 Microphone Replacement: passo 5, immagine 1 di 1
    • Hold phone securely in one hand and pull the battery away from the phone with your other hand.
    Chiedi a FixBot
    Aggiungi Commento
  6. LG TP 1100 Microphone Replacement: passo 6, immagine 1 di 1
    • Use your screwdriver to unscrew the four screws from the back plate.
    Chiedi a FixBot
    Aggiungi Commento
  7. LG TP 1100 Microphone Replacement: passo 7, immagine 1 di 1
    • Turn phone to the side as indicated in the picture.
    Chiedi a FixBot
    Aggiungi Commento
  8. LG TP 1100 Microphone Replacement: passo 8, immagine 1 di 1
    • Remove the back cover that you just unscrewed and set aside.
    Chiedi a FixBot
    Aggiungi Commento
  9. LG TP 1100 Microphone Replacement: passo 9, immagine 1 di 1
    • Open the remaining parts like a book but do not separate the two pieces.
    • Do not tear the tape connecting the two pieces.
    Chiedi a FixBot
    Aggiungi Commento
  10. LG TP 1100 Microphone Replacement: passo 10, immagine 1 di 2 LG TP 1100 Microphone Replacement: passo 10, immagine 2 di 2
    • Rotate the phone so that the circuit board is in the palm of your hand and the part connected with tape hangs behind.
    • Use your opening tool to pry the circuit board from the front cover. Do not let the number pad to fall out.
    Chiedi a FixBot
    Aggiungi Commento
  11. LG TP 1100 Microphone Replacement: passo 11, immagine 1 di 1
    • To remove the microphone, insert your opening tool under microphone and push upward to pry microphone away from the front cover.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Cal Poly, Team 27-91, Amido Spring 2010 Membro di Cal Poly, Team 27-91, Amido Spring 2010
CPSU-AMIDO-S10S27G91
5 Membri
18 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 7
Ultimi 30 giorni: 28
Tutti i Tempi: 1,633
