Salta al contenuto principale
LG Refrigerator Upper Ice Maker Assembly Replacement
Cosa ti serve
  1. LG Refrigerator Upper Ice Maker Assembly Replacement, Unplug your refrigerator: passo 1, immagine 1 di 1
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser fan motor
    • Compressor motor and thermal overload device
    • Water supply valve assembly
  2. LG Refrigerator Upper Ice Maker Assembly Replacement, Open the doors: passo 2, immagine 1 di 3 LG Refrigerator Upper Ice Maker Assembly Replacement, Open the doors: passo 2, immagine 2 di 3 LG Refrigerator Upper Ice Maker Assembly Replacement, Open the doors: passo 2, immagine 3 di 3
    • Open both refrigerator doors fully.
  3. LG Refrigerator Upper Ice Maker Assembly Replacement, Remove the ice maker assembly screws: passo 3, immagine 1 di 2 LG Refrigerator Upper Ice Maker Assembly Replacement, Remove the ice maker assembly screws: passo 3, immagine 2 di 2
    • Use a #2 Philips driver to remove the screws that secure the ice maker assembly to the refrigerator door.
  4. LG Refrigerator Upper Ice Maker Assembly Replacement, Reposition the ice maker assembly: passo 4, immagine 1 di 3 LG Refrigerator Upper Ice Maker Assembly Replacement, Reposition the ice maker assembly: passo 4, immagine 2 di 3 LG Refrigerator Upper Ice Maker Assembly Replacement, Reposition the ice maker assembly: passo 4, immagine 3 di 3
    • Use a spudger to lift the bottom edge of the ice maker assembly. This action will release the assembly from the refrigerator door.
    • Pull the bottom edge of the ice maker assembly toward you to free it from the door.
  5. LG Refrigerator Upper Ice Maker Assembly Replacement: passo 5, immagine 1 di 3 LG Refrigerator Upper Ice Maker Assembly Replacement: passo 5, immagine 2 di 3 LG Refrigerator Upper Ice Maker Assembly Replacement: passo 5, immagine 3 di 3
    • Lower the ice maker assembly until you can access the connector located at the top of the assembly.
    • Squeeze the connector at the top of the ice maker assembly to release it.
    • Pull the connector straight down to disconnect it.
  6. LG Refrigerator Upper Ice Maker Assembly Replacement, Remove the ice maker assembly: passo 6, immagine 1 di 1
    • Remove the ice maker assembly.
Conclusione
Repair didn’t go as planned? Try some basic troubleshooting, or ask our  Answers community for help.
Bill Gilbert
Membro da: 06/30/22
30.088 Reputazione
213 Guide realizzate
iFixit Membro di iFixit
Staff
136 Membri
17.420 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 33
Tutti i Tempi: 130
