Introduzione
Use this guide to test and replace the flap door motor on your LG model LFX25973 refrigerator.
The flap door keeps outside air from entering the ice maker compartment. This prevents frost buildup, which could cause problems with the ice maker.
If the flap door motor won't operate, there will be one of two problems. If the flap door doesn't open, no ice will be dispensed and the ice may jam in the ice bucket. Conversely, if the flap door won't close, the ice maker may malfunction because of an ice/frost buildup.
Cosa ti serve
Unplug your refrigerator before you begin your repair.
Condenser Fan Motor
Compressor Motor and Thermal Overload Device
Water Supply Valve Assembly
To remove the left door handle, first open the right door.
Use a 2 1/2 mm hex wrench to loosen the set screws in the top and bottom of the left door handle.
Right side clips
Top clips
Left side clips (Note, the dispenser is being held upside down for the photo, so the upper left side clips are at the bottom of the photo.)
Use a spudger to pry out the top edge of the dispenser assembly.
Once you've created a gap, use your fingertips to pull the edge downward.
Use additional spudgers to unfasten the clips securing the dispenser assembly to the refrigerator door.
Grasp the top edge of the dispenser assembly in the middle and pull outwards.
Continue prying and pulling around the perimeter of the assembly to release it.
Squeeze the two multiple wire connectors and pull them straight off to disconnect them from the display board.
Do not attempt to remove the four-wire connector from the board as it is not removable.
Use a Phillips screwdriver to remove the 11 mm‑long screw securing the white circuit board holder to the dispenser assembly.
Lift and remove the circuit board holder from the dispenser assembly.
Squeeze and pull the flap motor connector to disconnect it.
Use a Philips head screwdriver to remove the three 12.6 mm long screws securing the motor in place.
Before installing the motor, partially screw in the lower left screw to help position the motor.
Touch one probe to each of the terminals at the same time.
