Salta al contenuto principale
LG Optimus T Screen Replacement
Cosa ti serve
  1. LG Optimus T Screen Replacement, Screen: passo 1, immagine 1 di 3 LG Optimus T Screen Replacement, Screen: passo 1, immagine 2 di 3 LG Optimus T Screen Replacement, Screen: passo 1, immagine 3 di 3
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Using the plastic opening tool to remove the phone’s back cover. At the top of the phone, there’s an indentation to put the tool into to pop the case off.
    Chiedi a FixBot
    Aggiungi Commento
  2. LG Optimus T Screen Replacement: passo 2, immagine 1 di 1
    • Remove the battery. There’s an indentation to the left of the camera lens.
    Chiedi a FixBot
    Aggiungi Commento
  3. LG Optimus T Screen Replacement: passo 3, immagine 1 di 1
    • Remove the six (6), J0 Phillip's head, 4.5mm screws.
    • Be sure to retain all screws for reassembly.
    Chiedi a FixBot
    Aggiungi Commento
  4. LG Optimus T Screen Replacement: passo 4, immagine 1 di 2 LG Optimus T Screen Replacement: passo 4, immagine 2 di 2
    • Remove interior case. There are indentations on the top and bottom of the phone. Using a spudger, remove the interior case.
    • You might have difficulty popping the interior case off, and a more durable prying device may be needed.
    Chiedi a FixBot
    Aggiungi Commento
  5. LG Optimus T Screen Replacement: passo 5, immagine 1 di 1
    Strumento utilizzato in questo passaggio:
    • Pull up connector tab
    • Connector tabs may be difficult to remove, and tweezers may be required to assist removal.
    Chiedi a FixBot
    Aggiungi Commento
  6. LG Optimus T Screen Replacement: passo 6, immagine 1 di 2 LG Optimus T Screen Replacement: passo 6, immagine 2 di 2
    • Remove SD card mount. Use a plastic opening tool to assist removal.
    Chiedi a FixBot
    Aggiungi Commento
  7. LG Optimus T Screen Replacement: passo 7, immagine 1 di 1
    • Use a J0 screwdriver to remove two 1.8mm screws from the charging port.
    • Charging port and motherboard are connected.
    Chiedi a FixBot
    Aggiungi Commento
  8. LG Optimus T Screen Replacement: passo 8, immagine 1 di 2 LG Optimus T Screen Replacement: passo 8, immagine 2 di 2
    • Remove connector tab. Then remove the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  9. LG Optimus T Screen Replacement: passo 9, immagine 1 di 2 LG Optimus T Screen Replacement: passo 9, immagine 2 di 2
    • Using a spudger, gently pry off the metal panel on the back of the screen attached by 4 retaining points.
    • Remove the screen from the front of your device.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Edward Farris
Membro da: 02/07/17
112 Reputazione
Una guida realizzata
Ohio State, Team 1-3, Wilder Spring 2017 Membro di Ohio State, Team 1-3, Wilder Spring 2017
OSU-WILDER-S17S1G3
4 Membri
15 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 6
Ultimi 30 giorni: 21
Tutti i Tempi: 408
