Salta al contenuto principale
LG Intuition Screen Protector Replacement
Cosa ti serve
  1. LG Intuition Screen Protector Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the device so the two bottom screws are shown.
    Chiedi a FixBot
    Aggiungi Commento
  2. LG Intuition Screen Protector Replacement: passo 2, immagine 1 di 1
    • Remove the two 7mm screws holding the back panel of the phone using the P5 bit and magnetic driver.
    Chiedi a FixBot
    Aggiungi Commento
  3. LG Intuition Screen Protector Replacement: passo 3, immagine 1 di 1
    • Carefully use the plastic opening tool to pry the back panel of the phone from the front screen. This will expose the battery and other parts.
    Chiedi a FixBot
    Aggiungi Commento
  4. LG Intuition Screen Protector Replacement: passo 4, immagine 1 di 1
    • Use the Phillips #0 screwdriver to remove the 5mm screw holding the metal bracket that protects the battery's ribbon cable.
    Chiedi a FixBot
    Aggiungi Commento
  5. LG Intuition Screen Protector Replacement: passo 5, immagine 1 di 1
    • Carefully use the plastic opening tool to pry the ribbon cable connecting the battery to the motherboard of the phone.
    Chiedi a FixBot
    Aggiungi Commento
  6. LG Intuition Screen Protector Replacement: passo 6, immagine 1 di 2 LG Intuition Screen Protector Replacement: passo 6, immagine 2 di 2
    • Gently raise the battery from its compartment.
    Chiedi a FixBot
    Aggiungi Commento
  7. LG Intuition Screen Protector Replacement, Plastic Motherboard Shield: passo 7, immagine 1 di 1
    • Remove the thirteen 5mm screws holding the plastic shield covering the motherboard using the Phillips #00 screwdriver.
    Chiedi a FixBot
    Aggiungi Commento
  8. LG Intuition Screen Protector Replacement: passo 8, immagine 1 di 1
    • Carefully use the plastic opening tool to pry the plastic shield from the motherboard. This will expose the motherboard and ribbon cables for each component.
    Chiedi a FixBot
    Aggiungi Commento
  9. LG Intuition Screen Protector Replacement, Camera: passo 9, immagine 1 di 1
    • Carefully use the plastic opening tool to pry the ribbon cable below the camera itself from the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  10. LG Intuition Screen Protector Replacement: passo 10, immagine 1 di 1
    • Using the ribbon beneath the camera lift it upwards and pull the camera out.
    Chiedi a FixBot
    Aggiungi Commento
  11. LG Intuition Screen Protector Replacement, Volume Buttons: passo 11, immagine 1 di 2 LG Intuition Screen Protector Replacement, Volume Buttons: passo 11, immagine 2 di 2
    • Slowly pull the ribbon cable upward releasing the volume buttons from the phone.
    Chiedi a FixBot
    Aggiungi Commento
  12. LG Intuition Screen Protector Replacement, Screen Protector: passo 12, immagine 1 di 2 LG Intuition Screen Protector Replacement, Screen Protector: passo 12, immagine 2 di 2
    • Carefully use the plastic opening tool to pry the ribbon cable below the volume buttons on the left side of the phone.
    • Carefully use the plastic opening tool to pry the ribbon cable to the left of the camera.
    Chiedi a FixBot
    Aggiungi Commento
  13. LG Intuition Screen Protector Replacement: passo 13, immagine 1 di 2 LG Intuition Screen Protector Replacement: passo 13, immagine 2 di 2
    • Carefully use the plastic opening tool to pry the wire that connects to the bottom home and back display buttons.
    • Carefully use the plastic opening tool to pry the second wire on the right side of the battery that also connects to the bottom home and back display buttons.
    Chiedi a FixBot
    Aggiungi Commento
  14. LG Intuition Screen Protector Replacement: passo 14, immagine 1 di 1
    • Carefully use the plastic opening tool to pry the motherboard from the front screen.
    Chiedi a FixBot
    Aggiungi Commento
  15. LG Intuition Screen Protector Replacement: passo 15, immagine 1 di 2 LG Intuition Screen Protector Replacement: passo 15, immagine 2 di 2
    • Remove the 5mm Phillips #00 screw below the volume buttons holding the plastic shield onto the screen display.
    • Remove the 5mm Phillips #00 screw on the top right of the phone.
    Chiedi a FixBot
    Aggiungi Commento
  16. LG Intuition Screen Protector Replacement: passo 16, immagine 1 di 1
    • Carefully pull the ribbon cable upward and away from the front screen display.
    Chiedi a FixBot
    Aggiungi Commento
  17. LG Intuition Screen Protector Replacement: passo 17, immagine 1 di 1
    • Carefully use the plastic opening tool to pry the screen protector from the display and motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  18. LG Intuition Screen Protector Replacement: passo 18, immagine 1 di 2 LG Intuition Screen Protector Replacement: passo 18, immagine 2 di 2
    • Slowly separate the front screen from the screen protector. This will remove the screen protector from the phone.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 13
Tutti i Tempi: 461
