Salta al contenuto principale
LG Incite Touch Screen Replacement
Cosa ti serve
  1. LG Incite Touch Screen Replacement, Battery: passo 1, immagine 1 di 1
    • Hold the phone camera-side up and locate the rear cover.
    Chiedi a FixBot
    Aggiungi Commento
  2. LG Incite Touch Screen Replacement: passo 2, immagine 1 di 1
    • Place a thumb below the camera, apply a little pressure, and slide the cover toward the bottom of the phone.
    Chiedi a FixBot
    Aggiungi Commento
  3. LG Incite Touch Screen Replacement: passo 3, immagine 1 di 1
    • Place the plastic opening tool in the small slot below and to the left of the battery.
    • Pry the battery upward to remove it.
    Chiedi a FixBot
    Aggiungi Commento
  4. LG Incite Touch Screen Replacement, Back Panel: passo 4, immagine 1 di 1
    • Using the #00 Philips screw driver, unscrew the four 4.5mm screws located around the battery compartment.
    Chiedi a FixBot
    Aggiungi Commento
  5. LG Incite Touch Screen Replacement: passo 5, immagine 1 di 1
    • Wedge the plastic opening tool between the screen and the body of the device, using care to avoid damaging internal components.
    • Gently move the tool around the perimeter of the screen to separate it from the body.
    • You should not completely separate the screen from the device in this step.
    Chiedi a FixBot
    Aggiungi Commento
  6. LG Incite Touch Screen Replacement: passo 6, immagine 1 di 1
    • Flip the device over so the battery compartment faces up.
    • Press the scroll wheel, located in the upper-left corner, into the device to avoid damage.
    • Gently insert the plastic opening tool into the seam between the frame and front cover to separate the back panel from the device.
    • The volume, lock, and camera buttons are loose, so be careful not to misplace them.
    Chiedi a FixBot
    Aggiungi Commento
  7. LG Incite Touch Screen Replacement, Motherboard: passo 7, immagine 1 di 3 LG Incite Touch Screen Replacement, Motherboard: passo 7, immagine 2 di 3 LG Incite Touch Screen Replacement, Motherboard: passo 7, immagine 3 di 3
    Strumento utilizzato in questo passaggio:
    • Use the metal tweezers to gently peel the yellow tab from the left edge of the phone at the two plastic bases.
    • Do not completely remove the tab from the body, it should still be connected to the phone by the orange plastic.
    • Repeat this for the white tab on the opposite side of the phone.
    • This tab also has two plastic bases adhering it to the edge of the phone.
    Chiedi a FixBot
    Aggiungi Commento
  8. LG Incite Touch Screen Replacement: passo 8, immagine 1 di 1
    • Insert your plastic opening tool underneath the speaker/camera panel, and gently pry it upwards.
    • Do not fully remove the panel! It should still be attached to the motherboard by a red and black wire.
    Chiedi a FixBot
    Aggiungi Commento
  9. LG Incite Touch Screen Replacement: passo 9, immagine 1 di 2 LG Incite Touch Screen Replacement: passo 9, immagine 2 di 2
    • Use the metal tweezers to gently lift the edge of the maroon tab, it should pop up easily.
    • Do not remove the tab completely, it should still be connected to the phone.
    Chiedi a FixBot
    Aggiungi Commento
  10. LG Incite Touch Screen Replacement: passo 10, immagine 1 di 1
    • Insert the plastic opening tool underneath the motherboard towards the bottom edge of the phone and gently pry it from its case.
    • Lift the motherboard and slide it towards you by hand to free it from the phone.
    • The call and end buttons may fall out when the motherboard is removed! Don't lose the buttons.
    Chiedi a FixBot
    Aggiungi Commento
  11. LG Incite Touch Screen Replacement, Touch Screen: passo 11, immagine 1 di 1
    • Remove the call and end buttons using the metal tweezers.
    Chiedi a FixBot
    Aggiungi Commento
  12. LG Incite Touch Screen Replacement: passo 12, immagine 1 di 1
    • Wedge the plastic opening tool between the screen and sides of the phone.
    • Slide the tool along the edge to loosen the screen.
    • Repeat for the opposite side.
    • Don't completely remove the screen yet to avoid damaging the screen.
    Chiedi a FixBot
    Aggiungi Commento
  13. LG Incite Touch Screen Replacement: passo 13, immagine 1 di 1
    • Wedge the plastic opening tool under the screen where the buttons were to loosen it.
    Chiedi a FixBot
    Aggiungi Commento
  14. LG Incite Touch Screen Replacement: passo 14, immagine 1 di 2 LG Incite Touch Screen Replacement: passo 14, immagine 2 di 2
    • Gently peel the touch screen off from the bottom of the phone.
    • Do not damage the yellow tab in the upper right corner of the phone.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 5 persone hanno completato questa guida.
Cal Poly, Team 2-18, Maness Spring 2013 Membro di Cal Poly, Team 2-18, Maness Spring 2013
CPSU-MANESS-S13S2G18
4 Membri
11 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 44
Tutti i Tempi: 1,560
