Salta al contenuto principale
LG G5 Rear Camera Replacement
Cosa ti serve
  1. LG G5 Rear Camera Replacement, Front Panel Assembly: passo 1, immagine 1 di 2 LG G5 Rear Camera Replacement, Front Panel Assembly: passo 1, immagine 2 di 2
    • While holding the battery release button, pull the bottom end of the phone out of the body.
    Chiedi a FixBot
    Aggiungi Commento
  2. LG G5 Rear Camera Replacement: passo 2, immagine 1 di 3 LG G5 Rear Camera Replacement: passo 2, immagine 2 di 3 LG G5 Rear Camera Replacement: passo 2, immagine 3 di 3
    • Insert the sim card eject tool (0.8mm sim card eject head) into the small hole on the sim card tray.
    • Press inward with some force to eject the tray.
    • Pull the sim card tray out of the phone.
    Chiedi a FixBot
    Aggiungi Commento
  3. LG G5 Rear Camera Replacement: passo 3, immagine 1 di 2 LG G5 Rear Camera Replacement: passo 3, immagine 2 di 2
    • Remove the two 5.5mm Phillips #00 screws from the base of the phone.
    Chiedi a FixBot
    Aggiungi Commento
  4. LG G5 Rear Camera Replacement: passo 4, immagine 1 di 1
    • Insert the plastic opening tool into the seam between the glass screen and the metal body.
    • Pry the glass from the body only a slight amount.
    Chiedi a FixBot
    Aggiungi Commento
  5. LG G5 Rear Camera Replacement: passo 5, immagine 1 di 2 LG G5 Rear Camera Replacement: passo 5, immagine 2 di 2
    • Insert the Spudger into the now open space between the body and screen.
    • Push inward to separate the screen even more.
    • Slowly slide the nylon spudger up the edge the phone till the screen pops out of the body.
    • When putting the screen back in, press the edges down from the top of the phone to the bottom. The screen should "pop" into place.
    Chiedi a FixBot
    Aggiungi Commento
  6. LG G5 Rear Camera Replacement: passo 6, immagine 1 di 2 LG G5 Rear Camera Replacement: passo 6, immagine 2 di 2
    • Peel the screen away from the body. The two parts should be completely separated.
    Chiedi a FixBot
    Aggiungi Commento
  7. LG G5 Rear Camera Replacement, Rear Camera: passo 7, immagine 1 di 3 LG G5 Rear Camera Replacement, Rear Camera: passo 7, immagine 2 di 3 LG G5 Rear Camera Replacement, Rear Camera: passo 7, immagine 3 di 3
    • Insert the plastic opening tool between the camera-ribbon connector and the motherboard, then pull up. It should pop out easily.
    Chiedi a FixBot
    Aggiungi Commento
  8. LG G5 Rear Camera Replacement: passo 8, immagine 1 di 2 LG G5 Rear Camera Replacement: passo 8, immagine 2 di 2
    Strumento utilizzato in questo passaggio:
    • After detaching the ribbon, carefully remove the camera using tweezers
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 34 persone hanno completato questa guida.
Cal Poly, Team 18-2, Forte Fall 2016 Membro di Cal Poly, Team 18-2, Forte Fall 2016
CPSU-FORTE-F16S18G2
4 Membri
21 guide realizzate
6Commenti sulla guida
This worked great and took me about 10 minutes!
Mark - Rispondi Condividi
Great instructions. This was my first time taking apart any phone. Everything went smoothly and my camera now works! thank you
Christopher Piatt - Rispondi Condividi
the camera is held down with sticky tape and I wasn’t comfortable pulling hard under the processing board, so I pulled the six screws holding that down and removed it first. Unfortunately for me the new camera still doesn’t focus…
Ray White - Rispondi Condividi
This worked great for me. I was a little nervous prying on my phone, especially when I heard the first POP. But after that, it was not hard at all. The new camera focuses great for me now and I can get back to taking great pictures with my G5!
Thanks for the detailed instructions, tools and affordable part!
Brad - Rispondi Condividi
You may want to mention that the original camera is glued in. It takes a bit of prying to pop it out.
Ryan - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 14
Ultimi 30 giorni: 57
Tutti i Tempi: 18,099
