Salta al contenuto principale
LG G4 Motherboard Replacement
Cosa ti serve
  1. LG G4 Motherboard Replacement, Back Cover: passo 1, immagine 1 di 1
    • Make sure the phone is powered off.
    • Remove the rear cover by placing the plastic opening tool in the groove on the bottom left side of the LG G4 and gently prying up.
    Chiedi a FixBot
    Aggiungi Commento
  2. LG G4 Motherboard Replacement: passo 2, immagine 1 di 2 LG G4 Motherboard Replacement: passo 2, immagine 2 di 2
    • Place the plastic opening tool at the bottom edge of the battery and lift up. Carefully remove battery with your hands.
    Chiedi a FixBot
    Aggiungi Commento
  3. LG G4 Motherboard Replacement: passo 3, immagine 1 di 3 LG G4 Motherboard Replacement: passo 3, immagine 2 di 3 LG G4 Motherboard Replacement: passo 3, immagine 3 di 3
    • Remove the eleven 3.9 mm Phillips #00 screws found at the back of the phone.
    Chiedi a FixBot
    Aggiungi Commento
  4. LG G4 Motherboard Replacement: passo 4, immagine 1 di 3 LG G4 Motherboard Replacement: passo 4, immagine 2 di 3 LG G4 Motherboard Replacement: passo 4, immagine 3 di 3
    • Once all the screws have been removed, place the plastic opening tool in the lower left corner and firmly lift the cover up.
    • Detach the cover with your fingers
    Chiedi a FixBot
    Aggiungi Commento
  5. LG G4 Motherboard Replacement, Motherboard: passo 5, immagine 1 di 2 LG G4 Motherboard Replacement, Motherboard: passo 5, immagine 2 di 2
    • Remove the following four press-fit connectors with the flat edge of a plastic spudger or opening tool:
    • Front-facing camera connector.
    • Rear-facing camera connector.
    • Digitizer connector.
    • The rear-facing camera may be held down to the frame with two sided tape. Try to move the camera with the spudger prior to lifting the motherboard If it does not budge, use the same tool to pry it from the frame to avoid damaging the connector cable in the next step.
    Chiedi a FixBot
    Aggiungi Commento
  6. LG G4 Motherboard Replacement: passo 6, immagine 1 di 2 LG G4 Motherboard Replacement: passo 6, immagine 2 di 2
    • Remove the motherboard by lifting it up using the plastic opening tool and your fingers .
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 56 persone hanno completato questa guida.
carolinavind
Membro da: 08/30/15
2.735 Reputazione
3 guide realizzate
USF Tampa, Team 16-5, Wollert Fall 2015 Membro di USF Tampa, Team 16-5, Wollert Fall 2015
USFT-WOLLERT-F15S16G5
4 Membri
24 guide realizzate
25Commenti sulla guida
Where can I get a motherboard? I have been looking everywhere with no luck.
nellyquicksilver - Rispondi Condividi
If you had it less then a year lg will send u a replacement but if your phone is damaged they will charge u just say it's not damage and swap the boards and send them the new one back so u won't be charged they won't notice I just did it
Alex - Rispondi Condividi
i have to ask did they ever notice with the swap???
mklb492 - Rispondi Condividi
If my phone has the boot loop problem and i change the board will mi picture still be there ??
josean ramos - Rispondi Condividi
Did you find a resolution to this problem? I am facing the same thing!
Shahad Shihab - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 6
Ultimi 7 giorni: 17
Ultimi 30 giorni: 60
Tutti i Tempi: 71,694
